Author: Subject: windscreen edge sharp or radius
Dale
posted on 6/9/15 at 05:10 AM Reply With Quote
I am looking for opinions on weather or not to put a radius on my windscreen. I have gone for an older lemans look and alot of the vintage screens do not have a radius on the top edge. The screen will be glued in flush to the front of the frame.
Should i radius the edge. I am also hoping to make the screen capable of deflecting a deer as there a lot around here.
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
tims31
posted on 6/9/15 at 08:09 AM Reply With Quote
Personally I think it would look better with a radius, plus the screen will probably be stronger with the radius and bonded to the frame.
Build: http://www.martinsfurybuild.co.uk/
posted on 6/9/15 at 11:59 AM Reply With Quote
I suspect that in the UK have a radius on the screen to meet IVA standards
mark chandler
posted on 6/9/15 at 01:24 PM Reply With Quote
Square looks nasty, I would have radius with the sides at maybe 15 degrees off vertical as well.
posted on 6/9/15 at 04:20 PM Reply With Quote
I'd also vote for a radius.
That car's going to look impressive when it's finished!
Dale
posted on 6/9/15 at 04:25 PM Reply With Quote
Looks like it radius edged is the consensus.
More of an angle would look better on the sides but then i would be looking through the side posts. Originally I was hoping to make it fold forward with brooklands left up but too much work for what little time i get to work on it.
quick edit with radius
dale
[Edited on 6/9/15 by Dale]
Dale
steve m
posted on 6/9/15 at 05:02 PM Reply With Quote
Needs more of a radius that's just a rounded off square
posted on 6/9/15 at 10:21 PM Reply With Quote
Radiused corners for sure.
Maybe its just me but the RH roll hoop looks like a cock.
Dale
posted on 7/9/15 at 12:28 AM Reply With Quote
02GF74, you have a good eye, after I figured out what you were saying( if i got it right and you ment crooked and not -looks like sh@t-), it was off by about 1.3 degrees. Luckily it was only tacked in so it should be straight tomorrow.
They would look much better about 6 inches shorter but they would be no higher than my ears.
Dale
Dale
DIY Si
posted on 7/9/15 at 07:39 AM Reply With Quote
I think he meant the top of the screen crosses the roll hoops at such a height as to make it look like a cock!
Imagine the car with the central vertical bar in each hoop missing below the windscreen top edge and it's a bit clearer!!
Sun Tzu, The Art of War
Dale
posted on 7/9/15 at 03:53 PM Reply With Quote
ahhhh you may be right. Either way I found a mistake which I am glad to have seen.
Dale
Dale
