Author: Subject: Maximum torque of a h/ duty type 9
Shooter63
posted on 19/10/15 at 07:57 PM Reply With Quote
As the title says, what would be the maximum torque that a fully modded type 9 gearbox ( spc or bgh e6 ) be able to handle in a kit car, say 700kg all up, I know the bgh states this but I presume that would be for a tin top, the tyres would be 888s. I ask this as I'm waivering between a N/A set up or a turbo as a winter power boost.
Shooter
madteg
posted on 19/10/15 at 08:15 PM Reply With Quote
I have been running 300 bhp through a standard type 9, i have just upgraded to a long ratio BGH box because of the ratio's. Anyway i have been working on the theory that the car is that light it breaks traction before the box breaks. I have done several track days running slicks, also broke a driveshaft and propshaft at Santapod. Hope this helps. Kev
jeffw
posted on 19/10/15 at 08:58 PM Reply With Quote
I ran 300 ft lb and was breaking an E8 BGH once or twice a year. A turbo will be much harsher on the box than the Rotrex was.
Dopdog
posted on 19/10/15 at 09:44 PM Reply With Quote
I did the same with my 270bhp striker minced a trans x box twice not sure of the torque but I seem to remember 250bhp being a quoted max but I may be wrong as I usually am
beaver34
posted on 20/10/15 at 08:41 AM Reply With Quote
i run 270lbft through a spc quaife gearset and thats been ok for the last 1,500 miles
have snapped a half shaft though launching hard
richardm6994
posted on 20/10/15 at 08:48 AM Reply With Quote
I'm running 270bhp and 303ftlbs through a standard type 9.......done about 5k miles and a few track days.
I'm also working on the theory of a light car and the wheels breaking traction with the road before breaking the box.......and because of this theory I'm really undecided whether or not to fit a ATB diff?!?!....
Dopdog
posted on 20/10/15 at 11:43 AM Reply With Quote
I would say you guys are not trying hard enough😊
Oddified
posted on 20/10/15 at 01:35 PM Reply With Quote
I think it's little bit down to luck, some have regular issues and some don't with decent power going through them.
Torque and grip are the main things of course but don't forget the clutch, an unsprung paddle is much harder on the box than an uprated sprung organic.
I have a type 9 in my car with a tranx straight cut kit inside, uprated sprung organic clutch, atlas axle, zf lsd, quaife shafts and when i do rwyb meetings i use Micky Thompson drag tyres. The launch is hard on the drive train and it's never broken the box, and that's not because i'm going easy on it either, lifts front wheels off the ground and does 1.5sec 60' times which anyone that does a bit of drag racing will testify isn't shabby by any standards.
I also change the oil regularly and use lucas shock resistant gear oil..
It's nearly 10 years old now and done around 15000 miles (mostly road miles of course though) and touching wood (the good luck type before someone says something! ) is still working well, i was out and about in the car this morning
Ian
Ben_Copeland
posted on 20/10/15 at 08:47 PM Reply With Quote
272bhp and 309ftlb. Running reasonably small turbo (low lag) 660kg plus me and standard type 9 v6 box. So far it's been fine but I don't sprint like JeffW so it's not under as much stress.
Ultimately it depends how you drive the car and what you do with it.
Ben
Locost Map on Google Maps
Enter Your Details Here
Paul Turner
posted on 21/10/15 at 12:16 PM Reply With Quote
Not really ragged my BGH type 9, a few sprints, List 1A road tyres and a 175 bhp Zetec is not exactly going to overstress it. Did a few trackdays when it had 208 bhp but only list 1A again and no race starts so again not exactly overstressing it.
But, before the type 9 it was fitted with its cousin, the type E with a Quaiffe Pro syncro set. The car had a steel 175 bhp x-flow and ran in National Mod-Prod hill climbs and sprints on 9" wide slicks. In 4 seasons it never missed a beat (once the initial problem was sorted) and is still going strong in a 250 bhp VX Westfield.
Mate has a BGH type 9 in his 250 bhp VX engine car. Its 20 years old next year and has not had a rebuild yet despite being on the track (sprints) all its life (sometimes on list 1A but mostly on 1B).
They are way better than the doom mongers would suggest.
