Author: Subject: Compomitive CXR 2
sam919
posted on 10/11/16 at 03:50 PM Reply With Quote
Compomitive CXR 2
As title suggests
Used on Caterham Superlight with big brakes, lowered wing stays , standard width rear arches and CSR style front arches. No rubbing, fouling or special alterations needed.
- 2 x 7.0 x 13 ET0 shod with 160/535/13 Radical Dunlop SP Sport SR1 Race tyre
- 2 x 9.0 x 13 ET20 shod with 170/575/13 tyres as above
All tyres in good condition and suitable for track days or testing no sidewalk damage or punctures, new this year.The Radical SP Sport tyre is used as s wet/ dry tyre in the SR1 championships.
All wheels in good/ excellent condition with no damage, curbing or cracks.They dont make the 9" rear anymore and its the widest you can get away with under standard Caterham arches.
Looking for around £600 and to be sold as a set.
Delivery within 50 miles of Glasgow , 0.30p a mile after. I'm going to Newcastle in Friday so can deliver on route.
07740 684 186
sarrenberg@hotmail.com
[Edited on 10/11/16 by sam919]
jeffw
posted on 10/11/16 at 04:43 PM Reply With Quote
Damn, wrong offsets....
Is that ET20 or ET-20?
[Edited on 10/11/16 by jeffw]
sam919
posted on 10/11/16 at 05:23 PM Reply With Quote
Ill double check later, but sure its ET20, ill get the backspace measurement.
jeffw
posted on 10/11/16 at 07:09 PM Reply With Quote
If you would please. They do look deeper than ET20. If they are ET-20 I'll take them.
sam919
posted on 10/11/16 at 08:13 PM Reply With Quote
They've an approx 105 mm backspace, so -20. The stamp says ET 20 but looks like it's wrong. I've measures both 9"s and they are the same?!
jeffw
posted on 10/11/16 at 08:59 PM Reply With Quote
That works, what about the 7Js, can you check the backspace on those as well.
I thought they looked more than ET20
sam919
posted on 10/11/16 at 09:20 PM Reply With Quote
They appear to be correct at ET0, they have a 101mm backspace. Both measured 👍
jeffw
posted on 12/11/16 at 06:22 AM Reply With Quote
pm'ed
sam919
posted on 12/11/16 at 07:08 AM Reply With Quote
To add to the equation as there is a lot of interest for just the 9" wheels. I also have a pair of matching 7", same as above.
So if anyone is after a full set of 7" wheels I could split this set up?
7" would accommodate a 185 and a 205 tyre for example, RGB run with 6" wheels , they used to anyway, with these tyres so 7" would give a little more width.
sam919
posted on 13/11/16 at 07:57 AM Reply With Quote
£500 bump
jeffw
posted on 13/11/16 at 09:37 AM Reply With Quote
I don't need the tyres or the fronts but I'll give you decent money for the rears.
[Edited on 13/11/16 by jeffw]
dome
posted on 14/11/16 at 09:34 PM Reply With Quote
How much would you want for the 4 7" alloys without tyres?
sam919
posted on 14/11/16 at 10:34 PM Reply With Quote
£400.
