ch1ef
posted on 5/7/18 at 06:17 AM |
Kitcar rear spoiler - Raw striker wing bgw
In very good condition, a rear spoiler of my Raw striker (but will easily fit other cars)
I am changing the style of the car, and so the spoiler will come with legs, and you will just need to make fixing brackets for the cage (but I can cut
off mine and give them to you)
Carbon fibre wrap
I am between Bristol and Bath, or can post for £20
Photo's in this link
https://www.facebook.com/marketplace/item/651060828561479
z2000
posted on 5/7/18 at 11:21 AM |
I'm interested...what is the width between the mounts? can they be moved or are they a fixed distance?
Could you also provide some dimensions? (width, length)
Thanks!
If it isn't broken; take it apart and fix it! Build PhotoBlog:
http://z2000.co.uk
ch1ef
posted on 5/7/18 at 11:35 AM |
The spoiler is 137cm overall with end plates. The width of the mounts is on sliders, so can be adjusted to any width. The spoiler blade is 14cm
across.
z2000
posted on 5/7/18 at 11:45 AM |
Thanks for the quick reply! I'd have to check the car (GBS Zero Race) but dimensions sound about right to fit.
Is there adjustment in the angle of the mounts? My rear stays looks at a shallower angle, nearer to 45 degrees I would say.
Mine looks similar to this:
[Edited on 5/7/2018 by z2000]
http://z2000.co.uk
ch1ef
posted on 5/7/18 at 11:52 AM |
The angle is not "adjustable", but it is a L bracket that clamps to the legs, so easy to trim/redrill to what angle you need
