Author: Subject: z cars mini
rash12
posted on 27/7/23 at 01:37 PM Reply With Quote
z cars mini
1972 classic mini z car
This mini started off its life as a 850 morris mini,
The z car conversion was started in 2008 and took 4 years,
It had a full nut and bolt rebuild on the body and all the necessary mods to accept the front and rear z car frames,
The car was built in ireland by o,learys garage independent mini specialists, originally built as a hillclimb car,
It consists of the z cars race spec v tec kit conversion with stiffer and stronger roll cage with crossed door bars fully welded,
This frame comes rear trailing arm kit, driveshaft kit, rear brake kit, handbrake kit, gear change kit and necessary cables,
Z cars front subframe kit which is much lighter and stronger than the original mini subframe this houses the z cars fuel tank large capacity and the z cars radiator,
The engine is a low mileage k20a vtec honda engine with a six speed lsd gearbox,
Z cars simpson stainless exhaust system 4 into 2 into 1,
Z cars induction kit,
Z cars 256mm big front brake conversion with billet aluminium bells and mounting brackets,
Drilled vented discs and wilwood powerlite calipers,
Rear brakes, z car discs with wilwood 4 pot calipers with handbrake,
Tilton adjustable pedal assembly with brake bias adjustment,
Dry cell battery,
Bucket seats with 4 point harnesses on z cars subframes,
Omp removable steering wheel,
Fire extinguisher,
Ecu master ecu mapped to the engine,
Digidash lite etb instruments,
13x7 minilights,
175/50 /13 yokahama A539 tyres all round,
Carbon fibre bonnet, boot, door cards ,and arch pack.
Will take a px ideally a nice westfield or 7 style kit car
Built to a high standard see pics , file off history with build pics.
Collection in person viewing welcome
pics in photos archive
£26000
[Edited on 27/7/23 by rash12]
