Author: Subject: Facet fuel pump and lots of injectors
djtom
posted on 23/6/08 at 04:26 PM Reply With Quote
Facet fuel pump. Removed as have upgraded to redtop pump to power the turbo beast! This is the standard one (silvertop?) and was running fine on my 120bhp xflow.
£10 plus £4 pnp
2l Zetec injectors - 2 sets of 4.
Taken from my donor engines. Not tested but the engines have run fine so I have no reason to doubt them. One set beige, one set brown, both same spec AFAIK.
Zetec 2l injectors 1
Zetec 2l injectors 2
£10 per set plus £3 pnp
Rover Turbo injectors
Were used on my Zetec turbo, but now removed as I've upgraded to some huge injectors. 230cc / min flow, good for over 200 bhp, would make ideal upgrade for tuned XE or similar. Much cheaper than buying some dodgy low impedance Cossie injectors!
£20 plus £3 pnp
Collection welcomed - free cup of tea if you do!
Tom
r1_pete
posted on 23/6/08 at 04:52 PM Reply With Quote
Interested in the pump, what pressure does it run?
Cheers.
Pete.
djtom
posted on 23/6/08 at 05:29 PM Reply With Quote
It's for carbs, not injection, so low pressure. According to a quick google search:
http://www.minisport.com/acatalog/info_FAC476087-K.html
it should be good to 150bhp and about 4 - 4.5 psi. I assume it's the "road" one, not the fast road or competition, but I'm not sure as it's gold all over so they must have changed the colours since it was made.
HTH
Tom
djtom
posted on 23/6/08 at 06:23 PM Reply With Quote
Sold to Pete, subject to payment. Robinj66 has second dibs if it falls through for any reason.
Thanks!
Tom
