tilly819
posted on 4/6/09 at 09:11 PM |
fuel pump
Hi all, i never considered that this would cause me a problem but were is a good place, internet site or neer nottingham to locate a high preasure
fuel pump i only seem to be able to find ones for carbs
Chears Tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
cd.thomson
posted on 4/6/09 at 09:14 PM |
linky
Craig
tilly819
posted on 4/6/09 at 09:18 PM |
not high enough preasure i need 65 psi / 4 bar (aprox) at idle
Tilly
adithorp
posted on 4/6/09 at 09:27 PM |
Tilly
Are you sure about that? Think you'll find 3bar pumps are the norm.
adrian
http://jpsc.org.uk/forum/
tilly819
posted on 4/6/09 at 09:40 PM |
just had a look in service manual read it wrong says 43psi standard i assume this is at idle, so is the preasure required to rise as the throtle is
opened or is it a flat rate preasue and its all done by the injectors,
sorry to be dumb but this is my first real dabble into EFI
Thanks Tilly
Chippy
posted on 4/6/09 at 10:25 PM |
Hi Tilly, the fuel pump will supply that pressure all day, regardless of how hard you hit the throttle, :-). How much is supplied to the injectors is
controlled by the fuel pressure regulator, which will be somewhat less than the pump puts out, hence the reason for the return to tank fuel line. Hope
that helps. Cheers Ray
