Author: Subject: Gearbox Oil Seal
RoadkillUK
posted on 26/6/05 at 06:02 PM Reply With Quote
Gearbox Oil Seal
Does anyone know where I can get an oil seal for my 4 speed ford box.
It's number 32.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
RoadkillUK
posted on 27/6/05 at 09:59 PM Reply With Quote
Cheers HiCost
Roadkill - Lee
www.bradford7.co.uk
DarrenW
posted on 28/6/05 at 08:32 AM Reply With Quote
GMS Capri spares
www.gmscaprispares.co.uk
0191 3771718
They go to a lot of shows as well or do mail order. They supplied my Type9 rear seal.
Are they easy to fit? I need to do mine before fitting the prop.
UncleFista
posted on 5/7/05 at 12:52 PM Reply With Quote
We ended up getting 2 seals from a local engineering co.
Half the thickness, so there's 2 of 'em in there now I've also degreased the whole car so we can put a new interior in there without getting it covered in gear oil, I feckin' 'ate the smell of gear oil
Fingers crossed, although if it does start leaking again I'll know where to get a proper one from
BTW Changing it was easy enough (once we'd got the axle off to remove the prop, I'm sick of taking the engine out
With it in situ, just twat the original 'til its misshapen enough to come out then drift the new one in. Not so much engineering as blacksmithing
Tony Bond / UncleFista
UncleFista
posted on 19/7/05 at 11:49 PM Reply With Quote
*update*
Started leaking within a few hundred miles
Since replaced with the proper seal from ebay.
Fingers crossed
