Author: Subject: ZX9R - What Oil?
PaulYDP
posted on 21/4/09 at 02:01 PM Reply With Quote
ZX9R - What Oil?
Guys,
What oil are you running in your ZX9R's - I got fully synthetic but I'm wondering if this could cause possible clutch slip and should I change to semi-synthetic?
Paul
aka Keith
posted on 21/4/09 at 02:06 PM Reply With Quote
I use rockoil semi syth. thats what came with from the builder, so thats is what I use.
cheers
craig
[Edited on 21/4/09 by aka Keith]
r1_pete
You must use motorcycle oil, not car oil, the additives in car oil are not compatible with wet clutches.
In my R1 I use Halfords fully synthetic bike oil, gets ridden hard and never had a problem with lube or cooling.
PaulYDP
posted on 21/4/09 at 02:28 PM Reply With Quote
I currently have castrol racing fully syn motorbike oil, I have yet to drive the car in anything other than first gear though - I just wanted to check what others were using.
Mr Whippy
posted on 21/4/09 at 02:37 PM Reply With Quote
as above, you must only use bike engine oil that is designed for wet clutches and no slick 50 like additives either
Kriss
posted on 21/4/09 at 03:50 PM Reply With Quote
castrol do one in Halfords for bikes, T4 something its called. used on my R1 and it pulled hard and felt mega last track day. bosh a filter in there too to make sure everything dribbles out.
r1_pete
posted on 21/4/09 at 04:44 PM Reply With Quote
That will be fine....
gordon h
posted on 21/4/09 at 05:00 PM Reply With Quote
i use bike semi done over 5000m
mistergrumpy
posted on 21/4/09 at 06:34 PM Reply With Quote
I use Halfords semi bike oil too. Don't like fully synth. since I had my Alfa. It just seemed too thin and had a habit of weeping out of the Alfa engine so I've fallen out with it.
dean100yz
posted on 21/4/09 at 06:44 PM Reply With Quote
Nothing wrong with a good quality semi synth. Fully is OK but can give clutch slip on some bike engines (it did on my last honda MX bike)
I run Castrol. Dont get any clutch slip and will change oil every 2500 miles which costs £30 odd quid
mackei23b
posted on 24/4/09 at 11:15 AM Reply With Quote
Semi synthetic in mine to!
