Author: Subject: Wanted: A locoster with a lathe + pillar drill!
me!
posted on 15/5/12 at 08:11 PM Reply With Quote
Evening all.
I'm after some one to make some parts for me, in exchange for beer tokens obviously! I would prefer someone who has the raw material- if not I could try and get hold of some and post it when I'm back from holiday next week.
1- one 5mm thick steel plate with some holes in
2- two turned steel tubes
3- two more turned steel tubes
4- one turned steel spacer with a M10 thread in the middle (or an 8.5mm hole and I can thread myself- something I can do!)
5- four injector blanking plugs in alu
6- six TB spacers in alu
If these pics/drawings aren't good enough the ones in my archive should be a bit clearer, or I can email them. Or I can re-do them if they are totally hopeless!
So, can anyone have a go at this for me?
Thanks,
Craig
tegwin
posted on 15/5/12 at 09:58 PM Reply With Quote
What kind of dimensional accuracy are you wanting?
I can help you with all of the above however, the steel plate would be cut with a jigsaw so you would have to file it square if it has to be perfect!
I have odd bits of material but would probs have to order some of it in.
www.verticalhorizonsmedia.tv
me!
posted on 16/5/12 at 08:07 AM Reply With Quote
Tegwin you have a U2U- thanks
FuryRebuild
posted on 16/5/12 at 11:51 AM Reply With Quote
Where are you based?
You might find your local laser-cutter can do them for you at a suprisingly low price and delightful level of accuracy.
If you can cad, you can produce the files the need for cutting and turning.
I use yorkshire profiles, but maybe not much use to you - depends on location.
www.furyrebuild.co.uk
