Author: Subject: Sierra OS drive shaft needed
jakeob
posted on 29/6/12 at 08:15 PM Reply With Quote
Anyone got a spare Drive shaft , Sierra push fit 795mm long
big-vee-twin
posted on 30/6/12 at 12:08 PM Reply With Quote
Believe I have one after doing what you have just done on the other side, I will check Dims.
Only problem is that they are heavy and post will cost. You can have it for £10+ post if it is suitable.
http://www.triangleltd.com
jakeob
posted on 30/6/12 at 06:09 PM Reply With Quote
Thats great!
Did you have a chance to measure it??
big-vee-twin
posted on 30/6/12 at 07:12 PM Reply With Quote
I've not measured it yet but I am certain it will be the type you are after will get chance to go into garage tomorrow am will let you know.
jakeob
posted on 30/6/12 at 09:42 PM Reply With Quote
Just give you a visual ,, its the bottom one in the photo i am after
drive shafts
drive shafts
big-vee-twin
posted on 1/7/12 at 10:39 AM Reply With Quote
Here it is I believe its same as yours, I measured it at 830mm end to end uncompressed, 28mm diameter.
[img]
[/img]
jakeob
posted on 1/7/12 at 12:55 PM Reply With Quote
Thanks for that,
Mine is only 24mm and 795 uncompressed
So not sure its the right one
