yellowcab
posted on 5/7/12 at 07:16 PM |
MK Indy Alloy Fuel Tank
Angled one that sits nice and low down, preferably with a sender please
yellowcab
posted on 7/7/12 at 07:56 PM |
If anyone does custom made alloy tanks, these are my requirements:
The tank would be 540mm wide.
The bottom of the tank would be 190mm deep
The top of the tank would be 120mm deep
The height of the tank would be 400mm high at the vertical edge
Ben_Copeland
posted on 7/7/12 at 08:18 PM |
http://www.alloyracingfabrications.com/fuel-tanks/lo-cost.html
Highly recommended and he'll make any size and fit any sender...
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
cosmick
posted on 7/7/12 at 08:46 PM |
If you are thinking of fitting a Hayabusa fuel pump, then it comes with a sender already fitted. so you get pump, regulator and sender all in one.
Mike
If it can't be fixed with a hammer then its probably an electrical problem.
yellowcab
posted on 7/7/12 at 08:52 PM |
Thanks Mike, didn't want to call you so late but you've answered my question...
One email I've had back from a ally fabricator is:
Hi There,
Am I right assuming the top front corner is 90 deg, and what outlets will you require, is the engine injection requiring a sump or an in ‘tank
pump.
Regards
Ben_Copeland
posted on 7/7/12 at 09:23 PM |
Sumped (unless intank) and usually 8mm outlets
[Edited on 7/7/12 by Ben_Copeland]
Ben
Roadster
cosmick
posted on 7/7/12 at 09:47 PM |
If you are fitting a Suzuki type fuel pump, then you would need a thick alluminium ring welded to the bottom of the tank to take the pump. it would
only require a breather at the top of the tank, a filler and the ring. the outlet is on the pump so no fitting required.
TimC
posted on 8/7/12 at 07:05 AM |
Give Martin at MK Engineering a call - he'll obviously have the measurements
and I can assure you that their tanks and other aluminium fabrications are rather nicely put together.
His prices are VERY keen too.
