Author: Subject: Wheel nut runner
johnH20
posted on 9/12/16 at 11:20 AM Reply With Quote
Wheel nut runner
I seem to spend a lot of time taking my wheels on and off for various reasons - a recent example being the balls aching process of rear toe adjustment. So for Xmas I promised to give myself a nut runner, not really worried about inbuilt torque control as I always use a torque wrench as a final check on tightness. Any suggestions on a specific tool or is it simply a case of getting a socket attachment for a cordless drill?
HowardB
posted on 9/12/16 at 11:43 AM Reply With Quote
I bought one of the bundled impact drivers,. really low cost in my case as it used the batteries that I had in common with all the drill drivers I had. The advantage of the impact driver is that it undoes the tight nuts without resorting to another tool.
hth
Howard
posted on 9/12/16 at 11:44 AM Reply With Quote
If you have a cordless drill then a socket attachment should do the job (it would for me).
steve m
posted on 9/12/16 at 11:51 AM Reply With Quote
As per Nick ^^^
Ive used my cordless drill for the spinning on and off the wheel nuts, but use a torque wrench to loosen and tighten the last bit
I use a cut down "caravan leg" socket/adapter in the drill, think its 19mm, but might be 17mm
Unless, I was doing it 5 days a week, I wouldn't buy a purpose built unit to do the job
HowardB
posted on 9/12/16 at 02:33 PM Reply With Quote
agreed ^^^ but the OP has promised himself one for xmas who are we to dissuade him ?
I have a dewalt as it uses the batteries from the drill drivers, a real no brainer. Once I had the impact driver in my hands it was really easy to find hundreds of other jobs that I could use it for.
Howard
LBMEFM
posted on 9/12/16 at 08:54 PM Reply With Quote
As the others I use my battery drill with a socket extension of which a I cut off the female end.
Matt21
posted on 11/12/16 at 07:47 AM Reply With Quote
cut the female end off a 3/8" ratchet extension bar and stick it in your cordless drill...
Instagram: @matt211988
Photobucket
My YouTube
Xtreme Kermit
posted on 11/12/16 at 12:04 PM Reply With Quote
I use one of these and a cheap battery drilly driver for winding the legs up and down on my caravan.
http://www.ebay.co.uk/itm/like/172106672746
gremlin1234
posted on 11/12/16 at 07:19 PM Reply With Quote
I have a set similar to these
http://www.screwfix.com/p/erbauer-socket-driver-set-3-pieces/6297D?kpid=6297D
Erbauer Socket Driver Set 3 Pieces
edit
drivers for 1/4, 3/8, 1/2 drive £4
[Edited on 11/12/16 by gremlin1234]
ken555
posted on 11/12/16 at 09:21 PM Reply With Quote
Go big or go home
posted on 12/12/16 at 09:02 AM Reply With Quote
Re-reading the OPs question and the thread made me think. I've always lived with using either a socket on an extension bar or just my fingers TBH. Can't say I've ever been in that much of a hurry (or in need of an F1 pit stop).
