Author: Subject: Rotrex
Yazza54
posted on 18/2/17 at 02:49 PM Reply With Quote
Rotrex
Been thinking about experimenting with a rotrex... will consider C30-74, 84, 94
I'm unhappy cos I eat and I eat cos I'm unhappy
Ugg10
posted on 18/2/17 at 03:04 PM Reply With Quote
Works well on the aerial atom Honda engines and Jeffw has one on his 400hp zetec Phoenix. Will need an inter cooler which may be interesting to mount in a libra and get good airflow over it. Bigger injectors may also be needed with a mappable ecu.
[Edited on 18/2/17 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Yazza54
posted on 18/2/17 at 03:30 PM Reply With Quote
Indeed, I have it all planned in my head I just need a basic kit or even the blower on its own...hopefully not costing the earth as the rest will be custom anyway
jeffw
posted on 18/2/17 at 04:51 PM Reply With Quote
What power are you looking for ?
Yazza54
posted on 18/2/17 at 05:09 PM Reply With Quote
Around 300
jeffw
posted on 18/2/17 at 05:35 PM Reply With Quote
2lt engine?
Yazza54
posted on 18/2/17 at 05:54 PM Reply With Quote
B18C6 type R, but plan to fit lower compression pistons and H beam rods. It's all be done before and the kits utilise a C30-94, but the kits are no use to me as it simply won't fit where it would normally on an integra/civic. Sounds like some of the slightly smaller C30 units would still be adequate, I just wanted to put the feelers out...
jeffw
posted on 18/2/17 at 09:55 PM Reply With Quote
Rods I can understand but I doubt you want to run lower compression pistons. Mine runs 10.5:1 and the TTS Honda kits don't change the pistons as far as I'm aware. The C30 units are all the same size and you would really need the 94 not the smaller ones.
jeffw
posted on 18/2/17 at 09:57 PM Reply With Quote
http://www.tts-performance.co.uk/civic-diy-full-race
Yazza54
posted on 19/2/17 at 06:46 AM Reply With Quote
Hi Jeff
Cheers will keep a lookout for a 94 then. I was only going to drop it to 10:1 from 11:1. From what I've read a standard B18C6 is somewhat limited to around 300 with its original 11:1 comp ratio. I think the K20 has lower dynamic compression in vtec so it's a little more forgiving.
That mount is nice but not really any use to me. I'm going to have to make my own plate and fit it above the alternator similar to how the Jackson kits are driven, there's no space anywhere else. Another reason for having to make my own plate is I'll have to design my own tensioner arrangement so the charger runs off the back of the belt... as my engine runs anti clockwise.
Do you run a C30-94 or a C38?
[Edited on 19/2/17 by Yazza54]
jeffw
posted on 19/2/17 at 07:00 AM Reply With Quote
C30-94
A lot of the TTS Honda kits (F20C etc) run the C38.
jeffw
posted on 19/2/17 at 09:19 PM Reply With Quote
http://www.uphillracers.com/showthread.php?t=13950
C30/94
Yazza54
posted on 20/2/17 at 06:19 AM Reply With Quote
C30/94
Messaged him but no response and I can't post on the thread being a new member with no posts :/
jeffw
posted on 20/2/17 at 06:24 AM Reply With Quote
I've asked him for an email address for you.
Yazza54
posted on 20/2/17 at 06:26 AM Reply With Quote
Thanks Jeff
Yazza54
posted on 20/2/17 at 07:26 AM Reply With Quote
He won't split the charger and hayabusa bits unfortunately
Yazza54
posted on 27/2/17 at 10:03 PM Reply With Quote
Bump still looking
Yazza54
posted on 19/3/17 at 06:56 PM Reply With Quote
Bump
