Author: Subject: Edis system
ady8077
posted on 3/6/05 at 07:23 PM Reply With Quote
Edis system
Hi
Anyone got a edis4, coil & VR sensor there not going to use?
Save me searching the scrappies
Adrian
big_wasa
posted on 3/6/05 at 08:50 PM Reply With Quote
yeh I can help you out m8...
I have the edis 4 with plug/wire ,vr sensor from a zetec no housing or wire.A set of spark plug leads and coil (coil is tatty ,it has a split in the plastic on 1 of the four mounting points but came from a runner)..
Are you going to Newark next Sunday??
Cost is the entrance fee(£10)
OR if you are building a megajolt im in need of the compnents to build mine I have board and chip and all the hardware but havn't got the will power to cross ref all the bits from cpc/maplin ect......Maybe we can sort somet.........
regards warren...................
ady8077
posted on 3/6/05 at 09:15 PM Reply With Quote
Hi Warren
Yes I'm planning to go Newark on Sunday
I'm also planning on building a megajolt
I was hoping to source the bits from RS, but havn't cross reff'd yet
Adrian
paulf
posted on 3/6/05 at 09:18 PM Reply With Quote
Warren I have managed to find some order numbers for most parts, some are Farnell and some RS, if of use i will type a list up.U2u me.
Paul.
[Edited on 3/6/05 by paulf]
big_wasa
posted on 3/6/05 at 09:33 PM Reply With Quote
Cheers Paul that would be good..
Hows the car running m8?
big_wasa
posted on 3/6/05 at 09:43 PM Reply With Quote
Hi Adrian let us Know if you want them...
I normally get as many edis 4's as I can from the scrapie and flog them on ebay at a tenner ago but because of the price of steel the scrapie I use has been squashing more than he has been breaking and I havn't been able to get any more...
[Edited on 3/6/05 by big_wasa]
ChrisW
posted on 4/6/05 at 11:51 AM Reply With Quote
I've got loads of EDIS bits. u2u me if you are stuck for anything.
Chris
big_wasa
posted on 4/6/05 at 03:19 PM Reply With Quote
ebay link....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=21654&item=4552606286&rd=1&ssPageName=WDVW
This guy does all the squirt/jolt bits inclueding the ecu,s........
ady8077
posted on 4/6/05 at 04:22 PM Reply With Quote
Hi Warren
Yep interested in the bits, does the coil pack have its connector?
I've also been trawling through the RS web site and think I've identified everything except the map sensor (which i probably wont need as i'm thinking of going TPS). It works out quite dear though as most bits have a min order.
I'll start a new thread and list it all for verification
Adrian
Stuart Ainslie
posted on 4/6/05 at 05:40 PM Reply With Quote
TPS on Megajolt
Adrian,
I was considering this as I have a set of nice BlackBird carbs courtesy of Warren that already have a TPS fitted.
I was advised via the Megajolt forum that I would be better utilising MAP than TPS, as the MAP gives a true indication of load on the engine as opposed to the 'heaviness' of the drivers right foot from TPS.
Could be talking total crap though....
ady8077
posted on 4/6/05 at 06:51 PM Reply With Quote
Hi Stuart
Yes MAP is best, but with twin webbers its hard to get a good vac signal, especially with fast road cams
Adrian
big_wasa
posted on 4/6/05 at 11:15 PM Reply With Quote
Yep I to was wondering about this ?
All the other big ecu players seem to use the tps as the third dimension..Again my carbs (r1)have this and I dont want to drill the manifold if I can help it.....
can the map sensor be mounted in the air filter or to just one of the intake tracts ?? Can anybody give any advice or experiance on this................
big_wasa
posted on 4/6/05 at 11:20 PM Reply With Quote
Hi Adrian I dont have the conectors for the coil or vr sensor today ,but I am planning on poping down the srapie on my day of to get one for mine....So I will grab a couple if I can............
regards warren
ady8077
posted on 5/6/05 at 08:21 AM Reply With Quote
Hi Warren
vac off one cylinder will pulsate, you can comman all 4 up and use a chamber to filter out the pulses
Have a look at http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?s=4e26550c4a286548c6bccbf792a19c55;act=ST;f=3;t=28764
Adrian
Ps good luck at the scrappies
big_wasa
posted on 5/6/05 at 04:29 PM Reply With Quote
Well I didnt want to do it, but hey ho....
Ive placed vacume take off's on each of the ports were the injector normally sits..I have used O rings awell as sealer....
big_wasa
posted on 5/6/05 at 05:47 PM Reply With Quote
Adrian ive just found that Newark show is week after next..Ive been looking at Luegos website
Newark show link
Still not much to look at next weekend
ady8077
posted on 5/6/05 at 07:07 PM Reply With Quote
Hi Warren
Didn't notice you had the wrong sunday in you previus post. Are you still going?
Adrian
big_wasa
posted on 5/6/05 at 09:23 PM Reply With Quote
yep on the sunday 19th...
were can I get a map sensor m8
[Edited on 5/6/05 by big_wasa]
ady8077
posted on 5/6/05 at 09:33 PM Reply With Quote
I havn't bought one yet
But
http://www.skpang.co.uk/catalog/product_info.php?cPath=23_39&products_id=48
sell it
Adrian
big_wasa
posted on 5/6/05 at 09:39 PM Reply With Quote
thanks
big_wasa
posted on 9/6/05 at 03:35 PM Reply With Quote
Hi Ady picked up the conectors for both coil and vr sensor m8.........
ady8077
posted on 9/6/05 at 07:06 PM Reply With Quote
Cheers Warren
Are you still bringing them to newark?
Adrian
big_wasa
posted on 9/6/05 at 08:38 PM Reply With Quote
Yep thats the plan......
