ADD
posted on 10/1/06 at 09:04 PM |
Air angle grinder
I am after a decent quality air angle grinder preferably 4" or smaller. Cheers Adam
Humbug
posted on 10/1/06 at 09:12 PM |
If it's like selecting an air guitar, it can be any size you like
posted on 10/1/06 at 09:14 PM |
If I can find it I have one that I haven't used in several years , will have a look for you but no promises I can find it .
posted on 10/1/06 at 09:32 PM |
ive just bought a smaller 3" air cut off tool for £20 or 30 from machine mart. Not bad for a new tool i thought. Bear in mind you will need a
monsterous compressor for an air grinder.
ADD
posted on 10/1/06 at 09:54 PM |
I have got a 3" air grinder that I bought from machine mart but even my 3/150 wont run it, it also wont run the die grinder I bought from
machine mart. After talking to someone who knows more than I do about these things and it seems the cheaper tools have less efficient air motors so a
better quality tool might solve the problem.
Triton
posted on 10/1/06 at 10:05 PM |
The only thing that will solve that is a bigger pump
www.tritonraceseats.com
www.hairyhedgehog.com
mangogrooveworkshop
posted on 10/1/06 at 11:02 PM |
Those tools eat air like theres no tommorow.
The die grinder you talk about runs no bother on a 3hp compressor. BIGGER PUMP IS THE ONLY WAY
ADD
posted on 11/1/06 at 12:20 PM |
Please enlighten me, 'BIGGER PUMP IS THE ONLY WAY' 3hp motor is enough, what do I need to change? Suppying air to a tool from the resevior
surley has nothing to do with the motor its more to do with the bores of the connectors and the tools motor. No???
posted on 11/1/06 at 12:59 PM |
I have a cut-off grinder that's pathetic on a springy spiral air hose - goes really well on a large-bore pipe.
It does eat air though - my 3HP compressor soon empties its 50 litre tank...
[Edited on 11/1/06 by David Jenkins]
posted on 11/1/06 at 03:30 PM |
Sorry ,not been able to find air grinder , if I come across it will let you know . The reason I haven't used it is apart from the fact you need
a good supply of air I found it to be Noisier than an electric grinder and also bloody cold to use
posted on 11/1/06 at 03:37 PM |
quote: Originally posted by rusty nuts
The reason I haven't used it is apart from the fact you need a good supply of air I found it to be Noisier than an electric grinder and also
bloody cold to use
And oilier (if that's a word) if you use an in-line oiler... after a while you find everything's covered in a thin film...
Does anyone do a small electric cut-off grinder?
mangogrooveworkshop
posted on 11/1/06 at 10:19 PM |
The way we have done it is to get a 15 mm I/D pipe from the compessor to the garage that improves the performance no end.
You still have to wait sometimes for the res to fill but we get long runs and you generally are not running flat out all the time anyway.I have
another 150 liter res but have yet to connect it up for the sand blaster.
We still keep a small compressor for the riviter and the nailer so we can take them to the boat yard or out of the wshop jobs.
caber
posted on 11/1/06 at 11:20 PM |
Your 15mm pipe will quite effectively increase your reservoir volume depending on its length! In the USa you can buy air tanks very cheaply from their
equivalent of Halfords (Kragens). they are handy for charging and throwing in the back of the pickup for small jobs or just hooking in line with the
garage compressor to give you an extra 20 litres, for some reason, probably pressure vessel regulations not available in the UK
Caber
