Author: Subject: mk2 axle brake bits
chris_smith
posted on 1/9/08 at 06:03 PM Reply With Quote
mk2 axle brake bits
i need all the drum brake internal bits springs etc , started fitting handbrake on sunday then realised threw all mine away (they were unsalvagable.)
cant find the slave cylinders either
if anyone has bits and bobs floating in the garage ill be more than happy to take them off your hands
cheers in advance
chris
DavidM
posted on 1/9/08 at 06:37 PM Reply With Quote
The springs are available as fitting kits for not a lot of money from motor factors, and I believe Halfords also stock them. The cylinders are also available from motor factors, and there are usually a number on Ebay.
HTH
Proportion is Everything
cjtheman
posted on 1/9/08 at 06:39 PM Reply With Quote
i think i got a pair of wheel cylnders if needed new not used
cheers
colin
Paul TigerB6
posted on 1/9/08 at 06:57 PM Reply With Quote
brake fitting kit en the Bay
chris_smith
posted on 1/9/08 at 07:16 PM Reply With Quote
i also need this bit below if anyone has them, if not are they part of the bit i can get from motor factors if not what is the technical name for it
cheers
chris
andylancaster3000
posted on 1/9/08 at 07:29 PM Reply With Quote
Are they the 8" or 9" drums? Might be able to help if is 9.
chris_smith
posted on 1/9/08 at 07:41 PM Reply With Quote
good question! no idea will try find out tomorrow (car isnt at home its in a lock up)
big_wasa
posted on 1/9/08 at 08:40 PM Reply With Quote
The rubber bits are no longer available.
rayward
posted on 1/9/08 at 08:52 PM Reply With Quote
but i have found something that does the job just as well!!!!
RoadkillUK
posted on 1/9/08 at 09:13 PM Reply With Quote
Just browsing through and I thought I'd look at ebay for you.
Here is what you are after, complete lot though.
Ebay Link
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
chris_smith
posted on 1/9/08 at 10:22 PM Reply With Quote
big wasa rayward i was meaning the handbreak lever part rather than the rubber
cheers
chris
