Author: Subject: Any suggestions?
JeffHs
posted on 1/9/16 at 02:31 PM Reply With Quote
Any suggestions?
Sorry. Try again. Sisters VW camper keeps failing. Always same problem yet numerous pros have not fixed. Runs fine for months but packs up on hols causing great stress. Occurs when it's hot at idle then splutters and dies. Will restart only when fully cold again. Has had new fuel pump NRV and filters, pump push rod, coil.
Broke down 3 times en route France but has just got home without missing a beat.
[Edited on 1/9/16 by JeffHs]
Jenko
posted on 1/9/16 at 02:43 PM Reply With Quote
Have all the earths been checked?.......COmmon for an earth to fail when hot...Look closely around areas where exhaust can heat components and wires...Sorry, probably not much help....Is it an old Beetle engine camper?.
MY BLOG - http://westfieldv8.blogspot.co.uk/
posted on 1/9/16 at 02:46 PM Reply With Quote
Old school stuff -------------Missing heat shield/insulator from under the carb.
Normally I would also say an ignition coil going open circuit when hot but as I see that has been changed so it leaves only a fuel vapour lock due to the fuel boiling.
[I] What use our work, Bennet, if we cannot care for those we love? .
JeffHs
posted on 1/9/16 at 02:47 PM Reply With Quote
Should have said. It's a 1973 water cooled.
JeffHs
posted on 1/9/16 at 03:27 PM Reply With Quote
Everybody else has said vapour lock too. I'll check the carb insulator when I get back from France
posted on 1/9/16 at 03:50 PM Reply With Quote
A quick check revealed these early T3 Wassers were prone to vapour lock the measures applied that are reported to work are converting to an electric fuel pump near the tank and insulating the fuel lines where they might get hot.
JeffHs
posted on 1/9/16 at 03:58 PM Reply With Quote
I keep telling my brother in law to fit an electric pump!. Perhaps he'll listen now.
posted on 1/9/16 at 07:22 PM Reply With Quote
Which model are we talking about ? 73 VW camper is likely to be a bay window
Non of which were water cooled. The LT van was water cooled but I don't think
they were made until later. If it is a bay window the most common engine was a1600
they suffered with the Bakelite housing for the fuel pump pushrod causing exactly
the symptoms you describe. A new housing will probably cure it . Air cooled VWs
never had insulation between the carb and manifold but make sure all tinware
engine bay seal and air hoses are correctly fitted.
JeffHs
posted on 1/9/16 at 07:40 PM Reply With Quote
Correction.Its A plate so 83/84, definitely not a bay window. (T2/T3?)
Dusty
posted on 1/9/16 at 09:34 PM Reply With Quote
Electric fuel pump sorted mine years ago. Ebay special facet cube alike. Used to start on the button after I fitted it, hot or cold.
posted on 1/9/16 at 10:27 PM Reply With Quote
Put a V8 in it....
Midlana when I find the space...
