<<  1    2  >>
Author: Subject: My TIG is here too! Trials are promising.
NS Dev
posted on 5/11/07 at 09:43 PM Reply With Quote
Originally posted by 907
Hi David,
Considering you didn't use filler wire that is a cracking first go with a Tig.
When you get some, you will find that those little pin holes will no longer be a problem.
I've had several U2U's about these welders and if I have been of help to any of you then I'm a happy bunny.
So, get out there, get welding, and next time there's a poll "scratch build or kit" lets see a few more votes for the chassis builders.
Who was it that had a sig, "Kits are for Girls"?
(No offence intended)
Good luck to all
Paul G
Second that!! The first pic is great, in fact to be honest i always end up with undercut doing that without filler!!
[Edited on 5/11/07 by NS Dev]
NS Dev
posted on 5/11/07 at 09:46 PM Reply With Quote
PS spark gap for the HF is not issue, that's how my large and (when new) very expensive ESAB AcDC TIG does it, actually uses a spark plug!!!
tks
posted on 5/11/07 at 09:54 PM Reply With Quote
Well guys i brought 2 of them
one 160amp 155 pounds
one 200amp 200pounds
Cheers..
Tks
Mansfield
posted on 6/11/07 at 10:01 AM Reply With Quote
There is plenty undercut, this weekend I should have some filler wire though.
Looking forward to that although I will miss two hands steadying the torch!
NS Dev
posted on 6/11/07 at 12:54 PM Reply With Quote
if you can get a remote foot pedal control (or do them have them as std? ) then you can get a smaller "non trigger" type torch which is so small that its easy to use one handed.
I have the same issue with the trigger torch on the TIG here at work, but at home I have a small WP20 non-trigger torch, the foot pedal does the switching and current.
I didn't realise how nice the torch was until I used some ones with triggers on, they feel SOOO clumsy by comparison.
only trouble might be I think the smaller torches are water cooled, mine certainly is, which could be an issue......
907 will be able to help you more if you need it
Delinquent
posted on 6/11/07 at 01:17 PM Reply With Quote
are spares readily available for these, or are they "generic"?
I'm looking at an AC/DC tig through someone recommended on here, but as a back up cheapy machine to that, these do look rather tempting.
<<  1    2  >>
