Author: Subject: 65mm Bar turning
MakeEverything
posted on 14/2/10 at 08:51 PM Reply With Quote
65mm Bar turning
Anyone know what these would cost to turn up?
Doesnt matter what metal, as long as its stiff enough to swage 2mm ali under compression.
[Edited on 14/2/10 by MakeEverything] Rescued attachment 50mm Swaging Tool.JPG
Kindest Regards,
Richard.
RichardK
posted on 14/2/10 at 08:52 PM Reply With Quote
What material? Do they need the flats on the sides?
Rich
Gallery updated 11/01/2011
MakeEverything
posted on 14/2/10 at 08:53 PM Reply With Quote
Rich
It doesnt matter what material, as long as its stiff enough to swage 2mm ali under compression.
They are supposed to be round, but its my first attempt at modelling with TurboCAD!
Kindest Regards,
Richard.
posted on 14/2/10 at 08:56 PM Reply With Quote
Hmm, have you got a proper drawing? I may be able to turn it up out of aluminum for you...
MakeEverything
posted on 14/2/10 at 09:00 PM Reply With Quote
I do, ill email it to you. what would it cost?
The only thing that it could do with is a 10mm extension to put through the hole before tightening down, but that was an after thought!
Kindest Regards,
Richard.
turbodisplay
posted on 15/2/10 at 12:25 PM Reply With Quote
I have turbocad too.
I have had a similar problem, i think it needs the autocad equivalent of the spline function, which smoothe the straight lines into curves.
Darren
