Author: Subject: rivet nuts?
Jamesfear
posted on 3/6/04 at 02:59 PM Reply With Quote
rivet nuts?
What’s the best way of getting around having to use rivet nuts?
What has everyone else done about this?
Or did you just go out and buy a rivet nut tool
James
Mk-Ninja
posted on 3/6/04 at 03:09 PM Reply With Quote
MK do a home made tool which comes with an assortment of rivnuts for less than £30. or see if you can borrow one from a builder local to you. (Where are you)
I'm sure I've got one, just don't know where I've put it
Jamesfear
posted on 3/6/04 at 03:16 PM Reply With Quote
I live in spalding near peterborough. Anyone have one near me?
zetec
posted on 3/6/04 at 04:35 PM Reply With Quote
I would suggest buying MK one as it works well and very useful. Once you start building you will end up using all the time.
Jamesfear
posted on 3/6/04 at 05:30 PM Reply With Quote
I have work around the parts that need them, but have now got to a point where i have to get them done.
Browser
posted on 3/6/04 at 07:20 PM Reply With Quote
You have a U2U sir!
greggors84
posted on 3/6/04 at 07:38 PM Reply With Quote
Where are most people using them? I have only used a couple so far...
Chris
The Magnificent 7!
Rorty
posted on 5/6/04 at 02:41 AM Reply With Quote
I used a pair of the plier-like Rivnut setters for most of the setting jobs about the place.
When I was making alloy wheels with bead locks though, I found hand pressure on the pliers wasn't sufficient to pull down the serrated Rivnuts required to secure the outer bead lock rings to the rims. So, I made a really simple hand held device which increased the pressure to set the Rivnuts really tightly. It required a lot less grunt on my part to set them properly.
Cheers, Rorty.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 7/6/04 at 12:05 PM Reply With Quote
Homemade Rivnut puller
You can pull Rivnuts with a bolt, washer and nut.
Put the nut onto the the bolt (ideally a cap head set screw, then the washer and then screw on the rivnut.
Put the rivnut into the hole and hold the bolt with an hex key or spanner. Now wind down the nut. This will compress the rivnut.
It helps if the rivnut is a tight fit in the hole to stop it spinning and lube on the washer helps.
I used this method on many locations where I could not get my pliers in and on round tube where I kept snapping mandrels when using the pliers.
The bolt and nut did not last long though.
JB
posted on 7/6/04 at 12:17 PM Reply With Quote
Look on my website - Locost - Special Tools section. There's a simple rivnut setting tool there.
You don't have to use a lathe - get a suitably sized thrust washer from your nearest bearing supplier (they're cheap) and use a lot of big washers. It's amazing how much difference the bearing makes.
Browser
posted on 8/6/04 at 09:10 AM Reply With Quote
You have a U2U sir!
James, I've sent you another U2U, d'you still want a lend of the setting tool?
Jamesfear
posted on 8/6/04 at 10:32 AM Reply With Quote
you too have a u2u
spalding clubgti host
