Author: Subject: GOPRO Camera.
ALLAN 14
posted on 2/3/16 at 07:21 PM Reply With Quote
GOPRO Camera.
Hi Guy's,
We have a GOPRO Hero 3+ camera and it has stopped working ,It works for few minutes and then stops,
We have tried all the fixes on the net but no joy.
Has any one had one repaired ? did it work alright afterwards.
AS they cost a lot and do seem to have a lot of failures does it have a built in life span?
Can anyone help with a solution.
Hope you can as I do not fancy buying a new one for it to only last 18 months.
Regards Allan
MsD
posted on 2/3/16 at 08:42 PM Reply With Quote
Mine did the same thing not so long back. I ended up getting a more expensive better sd card and it cured it. As you say you've tried advice from the net I presumed you've already tried this!
Good luck, Mark.
benchmark51
posted on 2/3/16 at 11:49 PM Reply With Quote
Have you tried another battery?
Not the same thing but I have a Samsung Galaxy S4. Had it for 2 years and it was starting to be a right cow. Shutting down when it felt like it then going into a boot loop, over and over. Had to plug it into the charger then restart it, then it would behave for a while. I bought a genuine Samsung battery on ebay and it is now like a new phone! Might be worth a try.
jossey
posted on 3/3/16 at 08:28 AM Reply With Quote
I had that issue it was just a battery. Plug it in to a usb wall charger and see if it turns off.
David Johnson
