Author: Subject: Aluminium Welding - Teesside/N Yorks
Matt21
posted on 18/11/16 at 11:34 AM Reply With Quote
I'm looking for someone who can weld aluminium to do a little job for me.
Can anyone on here do the job or know someone/somewhere that can do it?
I have an alloy radiator which has an inlet going straight into it, however I need it to be at a 90degree angle pointing kind of straight up.
If needs be I can get the bits of pipe sorted and ready to weld, but if you/they have the bits required to do the full job then that's easier for me
As the title says, I'm in the teesside/north yorkshire area
Instagram: @matt211988
Photobucket
My YouTube
posted on 18/11/16 at 12:17 PM Reply With Quote
Have you looked at (can you use) hoses to do the same job?
A1
posted on 18/11/16 at 12:50 PM Reply With Quote
AS Performance are that way.
BATHO
posted on 18/11/16 at 03:22 PM Reply With Quote
I can do that for you..... But I'm in the Midlands?
Matt21
posted on 20/11/16 at 11:35 AM Reply With Quote
I looked into postage, but it's pretty pricey to send it and return it to the midlands unfortunately.
It's connected by a hose now, the problem is I had to raise the steering rack around an inch to get the hose under it which has led to horrendous bump steer.
If the inlet was at a 90 angle I could put the rack back where it is supposed to be and solve some of my issues
I'll check out AS Performance
It doesn't even need to be a car related place, just someone that can weld!
Out of interest batho, what sort of price would I be expecting? I know you can't see what needs doing, but hopefully my description made sense enough to get a rough idea?
Photobucket
My YouTube
BATHO
posted on 20/11/16 at 11:59 AM Reply With Quote
Well if you have the pipe cut at the right angle and marked up where you want it welding on.
£15 I'd leak test it too.
Martin
Matt21
posted on 20/11/16 at 04:10 PM Reply With Quote
u2u'd
Photobucket
My YouTube
