Author: Subject: Wooden Wheels
ken555
posted on 5/2/18 at 03:09 PM Reply With Quote
Wooden Wheels
Humor me.
But I'm thinking of making a set of Ply wheels for the Donor car.
2 sheets of ply fixed together, then 4 rough circles cut from it.
I need the alloy wheels off the car, and it's stored outside.
It does need to be moved now and then, otherwise I would put it on bricks.
Any other bright idea's as it weights around 500KG so above the simple pallet on casters approach.
HowardB
posted on 5/2/18 at 03:16 PM Reply With Quote
I have some flame cust steel discs "wheels" on my trailer - what might be better and cheaper could be a trip to the scrappy and buy 4 steel wheels and pay by the kg?
hth
Howard
joneh
posted on 5/2/18 at 03:19 PM Reply With Quote
As above, I think if they get wet you're in danger of having one collapse when you next lean against it. Buy some scrap ones.
theduck
posted on 5/2/18 at 03:40 PM Reply With Quote
With the above, most scrappy will be 10 a wheel with tyre
ken555
posted on 5/2/18 at 03:58 PM Reply With Quote
13" with 4" PCD is the problem.
Did think 4 spacesavers and drill mounting holes out.
pewe
posted on 5/2/18 at 05:57 PM Reply With Quote
Someone abandoned a Sainsbury's type trolley near our house.
It only took a few cuts with Mr Angrygrinder and a couple of pieces of 20mm SST welded on to raise the bottom tray to horizontal.
Certainly man enough for the F27 (650kg) and the beauty of it is the wheels swivel.
HTH. Cheers, Pewe10
ken555
posted on 5/2/18 at 08:12 PM Reply With Quote
HTH. Cheers, Pewe10
Didn't know they could take that weight.
I have been eyeing up the local communal bins they have in certain city streets.
A trolley might be easier to cut up in a discreet place to get it home
TQ_uk
posted on 6/2/18 at 10:04 AM Reply With Quote
Shame you're not closer, I've a bunch of Morris Minor wheels that are 4" PCD. But they're at my parents in Kent....
TQ_uk
posted on 6/2/18 at 10:07 AM Reply With Quote
Or get some 100mm from scrappy and file the holes out slightly?
Mr Whippy
posted on 6/2/18 at 12:28 PM Reply With Quote
tbh I think your wooden wheels will work just fine, two 12mm sheets glued together would be more than up to it
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
907
posted on 6/2/18 at 10:50 PM Reply With Quote
Having just built a garage extension from ply I would have thought that rough scrappy wheels would be cheaper.
The one and only member of the Suttol Owners Club. Now also the MX5 Owners Club. A few more in that one.
llionellis
posted on 7/2/18 at 04:49 PM Reply With Quote
I see no problem, it's been done before https://www.youtube.com/watch?v=P4qB6n1cm04
ken555
posted on 7/2/18 at 07:12 PM Reply With Quote
We have a place nearby that is trying to get rid of specialised packing crates, that have come back from offshore.
They recycle wood into things, but can't use they ply as it's full of nails/staples.
http://woodrecyclability.co.uk/
[Edited on 7-2-18 by ken555]
