Author: Subject: Aftermarket ECU questions
J666AYP
posted on 28/4/18 at 09:51 PM Reply With Quote
Hi gents,
Just trying to work out a few things that you guys might be able to help with...
1. With a aftermarket ECU can the original engine loom be used? (original plug cut off and correct one joined on).
2. If number 1 is not a option could anyone recomend a one stop loom/ECU guru who can do both for less than a F1 teams budget?
3. My engine has VCT, is this something that can be run on a sensible priced ECU? Or should I just delete it for ease of mapping?
4. Do any aftermarket ECU's come with a built in security system like the Ford PAT's system?
Thanks in advance for any help gents!
Jay
Ugg10
posted on 28/4/18 at 10:09 PM Reply With Quote
Some aftermarket ecu’s come as a plug and play. Emeralds do conversion looms (or will plug into a river k series), I think ME221 does version for plug and play and has vct, there are a number for MX5’s as well.
Motorsports Electronics does a stand alone vct controller as most aftermarket ecu’s don’t have full vct control only vtec on/off systems but the number is getting bigger as more kit car engines have them (mx5, st170, Honda vtec, Toyota Vvti etc.).
What engine are you running?
[Edited on 28/4/18 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
mackei23b
posted on 29/4/18 at 10:38 AM Reply With Quote
Megasquirt also has a number of plug and play options
J666AYP
posted on 29/4/18 at 11:44 AM Reply With Quote
Thanks for the input gents. Sadly none of the retailers make plug and play looms for my engine (2.3 Mercedes kompressor). So I will need a loom made or a universal loom that I can have wired in.
Jay
Ugg10
posted on 29/4/18 at 07:32 PM Reply With Quote
If you go for an aftermarket main loom then there are a number of kit car ones about just google plus most seven mistletoe manufacturers may well sell you one of theirs that may already be configured fir you choice of ecu if emerald or omex (two most common). This will do ignition switch, starting circuit, ignition, lights, wipers/heater if required, reverse switch, brake test etc. Most aftermarket ecu’s only need earthing plus permanent and switched live to work. The ecu can usually be bought with a 2m flying lead engine loom for all the sensors, injectors, coil etc. And can often control the fuel pump and rad fan. All sensors and other auxilliary stuff is configured in software.
jester
Contributor
Posts 174
Registered 21/5/17
Member Is Offline
Photo Archive Go!
Building: brought Jester.building a Jester own a Striker
posted on 29/4/18 at 09:54 PM Reply With Quote
Jay
If your in the oxfordshire area this Guy is worth a call for the loom build
http://www.witneycarelectrical.co.uk/
Schrodinger
posted on 30/4/18 at 06:56 AM Reply With Quote
The basic Emerald ecu comes with a plug and pins with a list of where the pins connect too. If you cut off the plug from your motor it should be no problem to attach the Emerald plug. Speak to Emerald, they are certainly very helpful.
Keith
Aviemore
