Author: Subject: Locost flat surface plate
Slimy38
posted on 26/8/18 at 10:56 AM Reply With Quote
Just out of interest, what's the best/locost option for a flat surface reference? Various Youtube engineering videos shows the use of a big block of granite for measuring flat surfaces, blade sharpening surface, etc. Would a kitchen worktop piece work?
davew823
posted on 26/8/18 at 11:36 AM Reply With Quote
Surface plate
Just use a plate of glass. The thicker the better, less chance of you breaking it if something gets drop on it.
Davew823
mcerd1
posted on 26/8/18 at 03:20 PM Reply With Quote
they are called surface tables / plates - very precise flat surfaces for precision measurement to be used with a vernier height gauge (or better)
made from granite, glass or cast iron depending on your budget
how accurate do you need it to be ?
[Edited on 26/8/2018 by mcerd1]
Mr Whippy
posted on 27/8/18 at 11:30 AM Reply With Quote
glass is quite flexible, it's smooth not flat
steve m
posted on 27/8/18 at 04:15 PM Reply With Quote
Ive got a bit of plate glass, 3/8 thick, and that seems to be flat,
might not be 100% flat, but near enough to get a straight edge, and check cylinder heads
posted on 27/8/18 at 06:10 PM Reply With Quote
It all comes down to the level of accuracy you require - a tool room would require a first-rate cast iron job that weighs a ton and costs a fortune.
If all you want to do is check the flatness of a piece of engine that usually seats against the block with a gasket then a good piece of new, thick float glass is more than sufficient. I use a chunk of marble hearth that is more than sufficient for my needs.
You could always buy 3 raw castings and make your own cast iron surface plate (3 plates, to be precise) if you have a lot of time, know how to use marking blue and know how to use a scraper! LINKY
hughpinder
posted on 28/8/18 at 08:04 AM Reply With Quote
The'old' standard cheap option for model engineers was the glass plate from a photocopier.
