Cita
posted on 25/1/05 at 08:01 PM |
RHS bend
Hi guys,
i need to have a section of RHS 20 x 1.5 bend half a circle with radius 80 mm.
Any suggestions-idea's other than impossible please?
Lawnmower
posted on 25/1/05 at 08:09 PM |
Does it have to be strong/structural?
If not you could cut slits into one side and bend it, then weld it back together.
What part is it for.
Mark Allanson
posted on 25/1/05 at 08:53 PM |
It would be stronger to make up 2 'C' shaped bits of plates used as the upper and lower, and bend some 1" strap to make the sides. I
don't think you could bend down to such a tight raduis without some serious bulges/splits.
Cita
posted on 25/1/05 at 08:55 PM |
posted on 25/1/05 at 08:57 PM |
80mm is a very tight bend cita... doing it marks way wouldnt be that hard either.
Professional fabricators use a special bending tool that neatly collapses the sides, allowing the piece to bend. Have a look at a stacking chair made
of square steel to see what I mean (if it's got nice rounded bits, that is! )
posted on 25/1/05 at 09:21 PM |
Hi Cita,
Why don't you try Martin Keenan @ MK Engineering. He's pretty handy at bending tube and box
section. The Indy and GT chassis both feature some nicely bent box sections.
HTH
Nick
posted on 25/1/05 at 09:25 PM |
It's a fair old trek to MK from Belgium.
Mark Allanson
posted on 25/1/05 at 10:05 PM |
Its usually done by pre collapsing the inner wall to prevent the bulging problem
Rorty
posted on 26/1/05 at 05:45 AM |
80mm is doable for that size of tube with a square upsetting die, but the only problem is, 80mm is not a standard size; 75 is the closest.
If you have a tube bender, then you could turn a temporary die for it out of maple or beech which would last for quite a few bends.
You may be able to find an engineering works that could do it for you. As David Jenkins hinted, a steel furniture maker may be a good starting point.
Cheers, Rorty.
907
posted on 27/1/05 at 09:03 PM |
Hi All,
As Mark suggests, make them from sheet.
I'v used 8 off 90deg bends on my chassis.
4 for the rear corners, 4 for the scuttle.
I made 2 rings, and after welding & cleaning up,
cut each ring into 4.The advantage of welding a
ring is that it does't distort out of shape.
Paul G
Rorty
posted on 27/1/05 at 09:33 PM |
quote: Originally posted by 907
Hi All,
Paul G
That's as nice a bit of Locosting I've seen for a while.
Cheers, Rorty.
907
posted on 27/1/05 at 10:14 PM |
Thank you Rorty.
Paul G
ps You have just made me think of a new signature.
posted on 28/1/05 at 11:41 AM |
That is a very nice bit of work, I'd be dead proud of that!
Cita
posted on 28/1/05 at 04:38 PM |
Bloody hell!!! (sorry guys)
Paul THAT is a nice bit of metal working!!!
I never can get to that with my skills so instead i will try to bend the tube...probably without succes.
