Author: Subject: Aluminium bolt supplier?
Northy
posted on 22/4/05 at 07:37 PM Reply With Quote
Does anyone know of a reasonably priced Aluminium bolt supplier? On-line would be nice
Graham
mangogrooveworkshop
posted on 22/4/05 at 08:07 PM Reply With Quote
PROBOLT
Not the cheapest but top class stuff availible in mixed 50 ect. The also look brill.
WWW.TASTYNUTS.COM
http://www.tastynuts.com/site/frameset.htm
ALUMINIUM TECHNICAL SPECIFICATION
MATERIAL SPECIFICATIONS: 7075T73 high tensile aluminium.
MANUFACTURING PROCESS:
Head - cold formed: shank - thread rolling.
ULTIMATE STRENGTH (PSI): Chemically brightened and colour anodised to between 8 and 12 microns thick.
YEILD STRENGTH (PSI): 490-560Mpa; stronger than mild steel.
WEIGHT: 60% lighter than steel; 40% lighter than titanium.
CORROSION: Anodised aluminium is not affected by saltwater, road film or mild acids.
APPLICATIONS: Aluminium is suitable for use in all non-safety critical areas e.g. mudguards, screens, fairings, engine casings, huggers, fuel caps, number plates, lamp units, exhaust cans, heel plates, clutch levers, exhaust manifold brackets, fuel cap surround, air filter plus many more.
SAFETY:
Do not use Aluminium in any safety critical areas.
TITANIUM TECHNICAL SPECIFICATION
MATERIAL SPECIFICATIONS: Grade 5 high tensile Titanium
Tapered Socket Cap - Forged Head with rolled threads. Flanged Hex Heads - Machined Heads with rolled threads. Other Items - Machined from bar
