Author: Subject: right angle drill attachment
posted on 5/4/06 at 03:21 PM Reply With Quote
as per title; anyone recommend a good but cheap one (up to 12 mm drill bits wold be fine).
(I see maplins do a cheap and nasty one)
posted on 5/4/06 at 03:26 PM Reply With Quote
You'll be very lucky to get a 12mm one - mine only manages 6-and-a-bit mm (1/4"
I'm not sure whether I'd want to hang onto a right-angle drive with a 12mm bit in it...
Got mine from a show, so I can't recommend a supplier (might have been Frosts).
DJ
Surrey Dave
posted on 5/4/06 at 04:16 PM Reply With Quote
Could you use a small right angled air drill with a carbide burr instead?
RazMan
posted on 5/4/06 at 04:39 PM Reply With Quote
I just bought one from eBay for about £7. It came in a blow moulded case and takes up to 10mm bits. I only bought it to do one specific job but it is quite durable so hopefully it will be in my toolkit for a while yet.
Raz
RazMan
posted on 5/4/06 at 04:42 PM Reply With Quote
....... or if you want a good one have a look here
Raz
posted on 5/4/06 at 04:48 PM Reply With Quote
i needed one last week, couldnt find one in time so i bought a ryobi right angle drill, it came as a pair (normal and right angle) of 14.4v drills for £80, very nice tools though. dont forget that the dewalt on ebay is a bare tool, no battery or charger! I love dewalts, but not that much!
[Edited on 5/4/06 by JoelP]
posted on 6/4/06 at 01:20 PM Reply With Quote
yeah, saw those one ebay; look a bit cheap and nasty but I guess it is throw away money.
re: 12 mm? ok, IO chose a figure out of thin air; since I plan to drill the chassis underside for fitting ali panels then 3 or 4 mm would be ample.
posted on 6/4/06 at 01:23 PM Reply With Quote
That's actually better than mine!
Works OK though, for the small stuff (like rivet holes).
[Edited on 6/4/06 by David Jenkins]
