Sizing an alternator belt
JoelP - 19/10/22 at 11:46 AM
Afternoon all.
Got the car back from Glasgow eventually - home at 5am! Saved 600 over the cost of recovery at least....
Anyway, the problem was the alternator belt vanishing. How do you pick a size, given that the donor would have had power steering too? Just measure and guess?
It's a pinto, only has to go round the drive and the alternator.
Tempted to just guestimate and order a few!
Fatgadget - 19/10/22 at 12:28 PM
Use a bit of string!...To work out length and therefore diameter.Voila.
obfripper - 19/10/22 at 12:48 PM
10x863mm is for a pinto cortina, should be the same for yours.
Dave
voucht - 21/10/22 at 04:41 PM
Here is how I did it :
https://vouchtroadster.blogspot.com/2013/06/modif-du-suppor t-dalternateur-custom.html
Beginning of the post does not concern the belt, so scroll down until you find date "15/04/2013" in yellow.
Hope that will help
JoelP - 21/10/22 at 07:15 PM
I used a tape measure and ended up 2 inches short! Sorted now though.
