theconrodkid
posted on 24/4/04 at 05:21 PM |
on a go slow
yo peeps,this compo i,m using here is sooooooooooooooooo slow,done a virus scan and gave it an enema,it wont de-frag,tried threatening it as well,any
ideas?
who cares who wins
pass the pork pies
I love speed :-P
posted on 24/4/04 at 05:22 PM |
a hammer?
Don't Steal
The Government doesn’t like the competition
pbura
posted on 24/4/04 at 06:26 PM |
A few suggestions:
1. Run Hijackthis.exe (you can get it at http://tomcoyote.com/hjt/. If you want, you can 'save log' and post the results
here. This is good for finding browser hijackers and crap programs in your startup routine.
2. You can also run PrcView (http://www.pcworld.com/downloads/file_description/0,fid,6102,00.asp), which shows everything running on your
computer. Might shed some light on trojan-type programs that are not exactly viruses, and you can use this to kill running processes so that you can
delete them with the Highjackthis program. You can use 'Save As' to save results as a text file if you want to share.
3. I've found that it's mostly shyteware that bogs computers these days, but you might try looking at free space on your hard drive.
Also run Scandisk and Defrag. If defrag is giving you grief, try running it in safe mode.
BoL,
Pete
Pete
Steve&Steve
posted on 24/4/04 at 08:30 PM |
What version of windows you running? and whats you computer spec?
That asside, go to RUN (on the start menu) and type 'msconfig' this will bring up System Config Utility.
Dont mess about here but go to the Startup tab at the top. You cant mess anythin up here really, you can always change it back in the same way.
There will probably be a lot of crap in this list (these are all programs that are starting up running in the back ground everytime you turn the pc
on)
Untick everything EXCEPT - systray & explorer (if they are there)
You may also want to leave Msnmsgr ticked if you use MSN messenger
Now look at the command column and make it bigger so you can see all of the line, Look at each one and re tick anything to do with you antivirus
software ie Symantec, Norton, McAfee, AVG ect. as you do want this running!
This should help speed it up a bit
Also remove any programs you dont need using add/remove programs
Run Scandisk as pbura said, check the automatically fix errors box (a standard scan should work), this should then allow Defragmentor to work.
Download Ad-aware 6 http://www.lavasoftusa.com/support/download/
its free, and run this it will clear 'bad' programs from your pc to put it simply.
Hope this helps.
theconrodkid
posted on 24/4/04 at 09:30 PM |
cheers chaps,ill do it tomorrow,allready used lavasoft,there were over 400 bugs there as for the compo spec,havnt got a clue,its all in polish
[Edited on 24/4/04 by theconrodkid]
who cares who wins
pass the pork pies
posted on 24/4/04 at 10:29 PM |
Press F8 on startup and choose safe mode, then disable the screensaver and defrag it. If things start up while it's running it starts from
scratch. Try spybot as well as adaware.
[Edited on 24/4/04 by Peteff]
posted on 25/4/04 at 06:29 PM |
on)
good stuff, but when i did that there are 12 programs starting, none of which i recognise. no systray or explorer either. should i turn it all off?
posted on 25/4/04 at 06:33 PM |
If you do it in safe mode you don't need to mess with msconfig
theconrodkid
posted on 25/4/04 at 07:13 PM |
tried to download a virus prog,it came up as not enough spare disc space,pie charts shows 20g of spare space?big hammer or out the window?
who cares who wins
pass the pork pies
Mk-Ninja
posted on 25/4/04 at 07:16 PM |
try winding the handle on the side of the box a bit fsater
I'm sure I've got one, just don't know where I've put it
theconrodkid
posted on 25/4/04 at 07:25 PM |
might jus buy another one,tower system with moniter for 999zl,thats about 150 squid to you n me
who cares who wins
pass the pork pies
I love speed :-P
posted on 25/4/04 at 07:31 PM |
[chant]
hammer, hammer, hammer
[/chant]
Don't Steal
