Author: Subject: No picture
ady8077
posted on 4/7/04 at 05:09 PM Reply With Quote
No picture
Hi all
When i went to turn on my pc the monitor didn't come on, i tried a spare and still the same. Unpluged the grafics card, couldn't see anything wrong, wiped the contacts and plugged it in and it now works
Any way to test if its faulty? Or could it be something else?
Adrian
posted on 4/7/04 at 05:55 PM Reply With Quote
Mains conector worked itself out a couple of mm or the graphics card just needed reseated in its Pci or AGP slot --- Both quite common.
Also possible that someother card tried to grab the graphics cards IRQ -- tends to happen more with Nvidia chipset cards.
ady8077
posted on 6/7/04 at 09:26 PM Reply With Quote
Hi again
Looks like it was my grafics card that is faulty, i have swaped it for an old one and my pc's working
Problem is i cant find the driver disk and im stuck in 16 colour mode, card had no mame on it only 3DFX, any suggestions on finding what card i've got and where to get drivers from
Thanks Adrian
pbura
posted on 6/7/04 at 09:38 PM Reply With Quote
The wonders of Google --
http://www.3dfx.com/
Pete
posted on 6/7/04 at 09:40 PM Reply With Quote
Start by looking at the chipset should be a clue somewhere on -- then the nightmare begins getting the exact model. ATI cards are usually clearly marked as are S3 and Trio Just hope it isn't an Nvidia Riva/ TNT they can be swines to set up even with the correct driver because they among other things don't allow proper dectection of plug and play monitors.
If you can't find the manufactures site on Google try http://www.driverguide.com/ it usually has them --- don't apply for a user name to download you will just get spammed log on as user "drivers" with password "all"
ady8077
posted on 6/7/04 at 09:41 PM Reply With Quote
Thanks Pete
I can't get google to load, i can only just read these post
Adrian
Mark Allanson
posted on 6/7/04 at 09:54 PM Reply With Quote
If its a voodoo, and you have broadband, I would email you drivers (voodoo's are 3dfx based, may work for other cards)
posted on 6/7/04 at 09:55 PM Reply With Quote
In situations like that I sometimes stick a Knoppix cd in and boot from that -- Knoppix hardware detection is ace if you watch carefully as it boots it will identify the graphic card model.
ady8077
posted on 6/7/04 at 10:16 PM Reply With Quote
Thanks guys
Looks like its a voodoo3 2000, well thats the driver i've just loaded and everything looks ok
Adrian
