Author: Subject: Best type 9 ratio
madteg
posted on 15/7/15 at 08:20 PM Reply With Quote
Best type 9 ratio
I am going to have my spare box rebuilt, what ratio should i go for. Engine is 2.1 zetec turbo with 320BHP max torque at 5800 RPM.
Thanks Kev.
posted on 15/7/15 at 09:03 PM Reply With Quote
Go for a high first at the very least . Who are you getting to do the box, might be worth asking them?. How's the motor home?
madteg
posted on 15/7/15 at 09:20 PM Reply With Quote
Thinking to get BGH to do it, motor home finished and runs great.
snapper
posted on 16/7/15 at 05:00 AM Reply With Quote
You've got the power to take a high 1st depends on wether you want a cruising 5th or a very high top speed
Get a gear speed calculator downloaded and have a play with the ratios
IMHO 1st needs to be 40+ 2nd 60+
Diff ratio needs to be low with a very close box and 3.9 is the lowest Sierra easily found
Your power should pull a 3.6 with ease but then gears need to be lower
A bit of a conundrum
I eat to survive
I drink to forget
beaver34
posted on 16/7/15 at 07:19 AM Reply With Quote
ive have a spc semi helical gearset in mine with long first.
i have the same power roughly and with a 8k limit mine does 58mph in first gear, its perfect like that
im running 205 60 r13, forgot diff ratio maybe 3.6
[Edited on 16/7/15 by beaver34]
livelee
posted on 16/7/15 at 03:08 PM Reply With Quote
Not as much power as you but I have the SPC box in mine, it's lovely. Running a 4.3 mazda lsd. 1st is just shy of 50mph.
