Author: Subject: ST170 exhaust manifold on a Blacktop
Rena
posted on 22/3/16 at 07:22 PM Reply With Quote
On my blacktop I have an exhaust manifold and silencer the previous owner built. I donīt really think he did a good job cause the pipes diameter are very thick and the silencer is 3", too much sound from it.
So, I need a new exhaust manifold which works better om my Blacktop. I donīt want to put too much money in this, so I have read itīs possible to use the exhaust manifold from a ST170 with some modifications.
My engines as standard, running R1 carbs and standard cams, but I will change cams next year. I will use the car on the road, not on a track.
Will the St170 and 2-2,5" silencer be good for my setup?
Thanks!
big_wasa
posted on 22/3/16 at 08:07 PM Reply With Quote
They are a 4-2-1 design so are tuned more for torque than top end. I havnt checked but I think they are equal length runners as well. My opinion is once modified they are as good as anything else a bloke in a shed can make and chirpy chirpy cheap cheap.
Got one sat here if your local for Ģ30. That's not much more than a laser cut flange.
Rena
posted on 23/3/16 at 04:23 AM Reply With Quote
Sounds like it would be good for road use. I will give it a try and see if it fits in my car.
I live in Sweden
Rena
posted on 29/3/16 at 03:56 PM Reply With Quote
Got it today but didn't fit as my engine mounts are just behind the manifold.
Could you maybe show a picture how you did with engine mounts in a seven with the st170 manifold?
Thanks!
Rena
posted on 29/3/16 at 06:20 PM Reply With Quote
Thanks!
big_wasa
posted on 3/4/16 at 06:27 PM Reply With Quote
I can't find any pictures of mine.
But some one else's. You get the idea.
Rena
posted on 4/4/16 at 06:54 AM Reply With Quote
Thanks!
Rena
posted on 12/4/16 at 07:47 AM Reply With Quote
Changed plans - I tried to mount me manifold in my car yesterday. Before I fitted it I knew I have to make a new engine mount, no problems to do.
But, even with a new mount, the manifold was to close to the frame - no space for engine to move.
So, therefore, it will be a winterproject to fix this.
Now I have to fix my old exhaust and re-use the exhaust manifold but change from the big 3" silencer to a smaller one. Thatīs why I have a questions.
I got to 2" pipes coming from the exhaust manifold. I must connect them to a Y-pipe. Will it work to have both A and B pipe as 2" or is B-pipe to small?
I have found a Y-pipe with A & B 2" but also a version with A as 2" and B as 2,5".
Which will work best? I know itīs not the perfect solution but as always, no time before season starts.
All content Đ 2001-16 LocostBuilders. Reproduction prohibited
Running XMB 1.8 Partagium [Đ 2002 XMB Group] on Apache under CentOS Linux
