Author: Subject: Internet access problem
designer
posted on 14/7/16 at 10:53 AM Reply With Quote
If I have signal strength of 'excellent' why can I only connect with 'limited access', which means I can't connect at all!
Slimy38
posted on 14/7/16 at 11:01 AM Reply With Quote
The two responses are looking at different things, they don't affect each other. You can have it the other way round, your signal strength can be one bar and yet you still have full access.
My first step in fixing a limited access issue would be to reboot the wireless router. My Sky router gets it roughly once a week nowadays.
posted on 14/7/16 at 11:06 AM Reply With Quote
I'm at work in Basingstoke and our internet access is at snails pace right now. I'm about to try and connect my laptop via my phone and see if it's any quicker!
loggyboy
posted on 14/7/16 at 11:17 AM Reply With Quote
On a mobile?
Depends on what signal type, a high E or G signal wont be as good as low 4g signal for connection speed, only good for voice calls etc
Mistral Motorsport
gremlin1234
posted on 14/7/16 at 11:28 AM Reply With Quote
I am guessing this is a windows machine using wifi.
limited access means it could not get an address, or the router isn't seeing the outside world.
turn your machine off and on again. if that doesn't work, do the same to the router.
ps always better to use a wired connection if practical.
mcerd1
posted on 14/7/16 at 12:44 PM Reply With Quote
even if its not practical in the long run - try using a wire
if works well wired - then you know its a wifi issue
if it still doesn't work then you know its a router / broadband issue.... (my money is on this)
posted on 14/7/16 at 03:59 PM Reply With Quote
Access speed seems back up to speed now - our IT guru thinks it may have been our network downloading and applying MS updates
