Author: Subject: Virgin box and multi TV's questions
steve m
posted on 13/8/17 at 10:16 AM Reply With Quote
Hi All
Ive recently HAD to change my upstairs Virgin media box, due to it being knackered, and now can not drive extra TV's off it,
We have the main VM box in the lounge, and that's fine,
The old VM box upstairs (office) used run the office tv and two spare rooms, and the garage TV, (sad I know!) as the old VM box had a TV out as well as scarts etc, so it was any easy hook up with splitters etc, obviously, if any of the other rooms wanted to change channels, it had to be done in the office, all of this worked fine
The new VM box has one scart one HDMI, one usb and one Ethernet connections, but no tv out port
Ideally, I am looking for a scart to coax lead, to drive all the other Tv's, but unable to find such an animal
Or is there any other way I can achieve what I had to before, and it has to go through coax, and not very long scart leads
steve
gremlin1234
posted on 13/8/17 at 11:00 AM Reply With Quote
you would need something like this
https://www.amazon.co.uk/Scart-RF-Aerial-Modulator-Converter/dp/B007FT8OAM
undoubted cheaper ones available
Slimy38
posted on 13/8/17 at 01:48 PM Reply With Quote
It's a shame the other devices don't have HDMI, it seems quite tolerant of long distance travel (probably because it's digital). I can see you can get devices to convert HDMI to SCART, and HDMI splitters are very common, perhaps running HDMI everywhere and then tapping a signal to a splitter in each room would work?
hearbear
posted on 14/8/17 at 11:07 PM Reply With Quote
You can't use the rj45 hdmi extenders and split the output to the other TVs.
3.9Ltr SSC Stylus should be fun
