Author: Subject: Type 9 gearbox spacer
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 16/5/21 at 02:32 PM Reply With Quote
Wanted type 9 to bellhousing gearbox spacer . Believe they are 16mm .
Any gathering dust anywhere chaps
snapper
posted on 16/5/21 at 03:30 PM Reply With Quote
30mm RetroFord do one
I eat to survive
I drink to forget
big_wasa
posted on 16/5/21 at 04:51 PM Reply With Quote
Is the v6 first motion shaft really 30mm longer ?
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 16/5/21 at 07:16 PM Reply With Quote
This box already has a 30mm spacer and has had shaft cut to length of standard box . The trouble with that is shaft now only sits 5mm into spigot bearing . I could get the 30mm spacer milled down to 15mm but thought I’d ask first .
[Edited on 16/5/21 by CRAIGR]
pmc_3
posted on 17/5/21 at 07:55 AM Reply With Quote
It might be a silly question Craig but if the shaft has been cut down to the length of a standard type 9, why does it need a spacer at all?
posted on 17/5/21 at 09:10 AM Reply With Quote
At a guess ,using a 4 cylinder bell housing on a v6 box?
snapper
posted on 17/5/21 at 10:53 AM Reply With Quote
32mm actually
I eat to survive
I drink to forget
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 17/5/21 at 02:36 PM Reply With Quote
Correct Rusty
With a 15mm spacer and the input shaft having been cut down it would be the same as a 4cyl type 9 . With the 30mm spacer the end of the input shaft will only sit in spigot about 4-5 mm including chamfer on shaft .
