Author: Subject: Length of monitor cable
spunky
posted on 19/11/06 at 10:05 AM Reply With Quote
Morning guys,
Any of you techy types tell me what the the maximum practical length of cable i can use to drive my projector before I get signal degredation.
Thanks in advance
John
The reckless man may not live as long......
But the cautious man does not live at all.....
whitestu
posted on 19/11/06 at 10:09 AM Reply With Quote
We put a lot of projectors into schools and 22-30m vga cables aren't uncommon.
Should be not problem with good quality cable.
I've got a 15m cable at home from PC to LCD telly and don't see any noticable difference in quality.
Stu
viatron
posted on 19/11/06 at 10:49 AM Reply With Quote
Also invloved in putting IT into schools, as already stated the major factor will be the quality of the cable, use cheap cable and you will get degredation on even a short length. Are you looking to project presentations and the like or Tv/video?
Mac
flak monkey
posted on 19/11/06 at 01:28 PM Reply With Quote
Yep, if you use decent cable you should be ok, and it wont make any noticeable difference. We have huge lengths of cable run in lecture theatres here (from the lectern to the back of the room) and it doesnt seem to make too much difference to the picture quality.
Sera
http://www.motosera.com
spunky
posted on 19/11/06 at 02:33 PM Reply With Quote
Thanks guys, Only needing about 10m, so no worries there.
John
Jasper
posted on 20/11/06 at 01:27 PM Reply With Quote
On the same note - can you sent a video signal down Cat 5 cabling to an LCD TV?
flak monkey
posted on 20/11/06 at 03:32 PM Reply With Quote
Not a brilliant idea as networking cable is twisted pair and due to this is not fully sheilded like video signal cables are. It would work no doubt, but you would likely get interference.
Sera
Jasper
posted on 20/11/06 at 03:38 PM Reply With Quote
How about wireless?
posted on 20/11/06 at 03:44 PM Reply With Quote
Not directly as twisted pair is not the right impedance for video, you will get ghosting etc. You can buy interfaces (essentialy an active balun) to do this, though for high bandwidth video like VGA they probably aren't cheap.
http://www.cadesigns.co.uk/tp2l-200.htm
Jasper
posted on 20/11/06 at 03:51 PM Reply With Quote
Bugger - I put some Cat 5 in when I had the wiring re-done - looks like I wasted my time on that one.
