Author: Subject: OT: graphics card socket
stuart_g
posted on 14/8/08 at 08:29 AM Reply With Quote
What is this socket called?
I need to get an adapter so I can plug a monitor into it but I don't know what this socket is called to look for one.
Benzine
posted on 14/8/08 at 08:43 AM Reply With Quote
Edit: I DUN A BAD
[Edited on 14/8/08 by Benzine]
r1_pete
its a 60 PIN D socket.
posted on 14/8/08 at 08:46 AM Reply With Quote
^^^^ they're all wrong.
google is your fluffy friend.
[Edited on 14/8/08 by 02GF74]
splitrivet
posted on 14/8/08 at 09:04 AM Reply With Quote
It is a DVI socket but a vesa DMS one meant for multi display I think.Fitting a new graphics card I would think is the easiest option.
Bob
stuart_g
posted on 14/8/08 at 09:25 AM Reply With Quote
Thanks for the replies, it is the dms 59 socket. I'll have a search and see what I can find.
Cheers.
saigonij
posted on 14/8/08 at 10:28 AM Reply With Quote
Matrox Dual Head cards use this socket - you need an adaptor lead that splits it to two monitors...
but if it was me, id junk it in favour of a ATI 4850. cheap and powerful.
chrism
posted on 14/8/08 at 10:35 AM Reply With Quote
Looks like a Dell machine to me, I have installed a few of these in the past and they came with two breakout cables one which plugged in and gave you two standard VGA connections and one that gave you 2 DVI connections, not sure if it is specific to Dell or not as some of there stuff is custom ordered/made, if you cant find the cable you may need to get one from dell which will probably not be cheap.
A little hard work never killed anyone, but why take the risk!
stuart_g
posted on 14/8/08 at 11:34 AM Reply With Quote
Found a dms59 to 2 vga adapter lead on ebay for £4.95 I'll try this first.
McLannahan
posted on 14/8/08 at 03:24 PM Reply With Quote
Stuart - I have one of those leads in my hand!!
It's from a Dell GX280 with the optional dual header VGA (expensive optional extra!)
Part number: CN-0g9438-52204-73d-2251.
Happy to drop in post for you?
stuart_g
posted on 14/8/08 at 04:22 PM Reply With Quote
Typical I have already bought the one from fleabay, thanks anyway
