Author: Subject: where does f/fox hide the bookmarks
mangogrooveworkshop
posted on 13/10/08 at 06:57 PM Reply With Quote
where does fire fox hide the favorite file.......going to change the hard drive
Werner Van Loock
posted on 13/10/08 at 07:05 PM Reply With Quote
Do a export, you can't just copy them from somewhere.
Go to organize bookmarks and export to html, you can later import that html again
Good pointer is to get a look at your logins and passwords stored, take a screenshot of it make sure you unhide the passwords first
http://www.clubstylus.be
McLannahan
posted on 13/10/08 at 07:10 PM Reply With Quote
I'd export them and then back that up..
Bookmarks - Organise Bookmarks - Import and Backup...
Hope that helps. Obviously Import them back in on the fresh build!
mangogrooveworkshop
posted on 13/10/08 at 07:13 PM Reply With Quote
cheers guys
Humbug
posted on 13/10/08 at 07:46 PM Reply With Quote
On my PC it is:
C:\Documents and Settings\username\Application Data\Mozilla\Firefox\Profiles\Profile name\bookmarks.html
If you back up that file you should be able to copy it to the new PC
hobbsy
posted on 13/10/08 at 08:41 PM Reply With Quote
You can just take the entire directory under the profiles (inc the weird directory name that ends in .default) then you change the profiles.ini to reflect that directory name in your new install.
Its all on the firefox site if you search for it.
That way you'll get EVERYTHING inc your stored passwords etc etc
mangogrooveworkshop
posted on 13/10/08 at 09:18 PM Reply With Quote
sorted thanks lads
posted on 15/10/08 at 07:01 AM Reply With Quote
Even easier if you us Mozbackup -- backs up & transfers all Firefox and Thunderbird settings
http://mozbackup.jasnapaka.com/ Rescued attachment 04-n.png
