Author: Subject: Wanted: Loan or hire of hot knife
TimC
posted on 3/3/18 at 10:49 PM Reply With Quote
Hi All,
The woven conduit that I’ve bought at considerable cost to wrap my loom is apparently much better cut with a hot knife. I was reasonably prepared to buy a cheap one - except they don’t seem to exist; entry level is c.£60.
Can anyone help? I’m happy to pay a deposit etc.
Schrodinger
posted on 4/3/18 at 08:25 AM Reply With Quote
I have used a cheap disposable craft knife, heated it with a gas blow torch and used that for similar cutting in the past.
Keith
Aviemore
posted on 4/3/18 at 09:17 AM Reply With Quote
You could also buy a cheap soldering iron (if you haven't got one already) and graft a craft knife blade onto the tip. If you get one with readily-available interchangeable tips (like an Antec) then you'll have a serviceable tool at the end of the job.
bonzoronnie
posted on 4/3/18 at 10:21 AM Reply With Quote
How about something like this.
Ebay item No: 182684842042
Comes with a hot knife attachment.
We use a similar one on the boats, a very handy bit of kit indeed.
rf900rush
posted on 4/3/18 at 10:24 AM Reply With Quote
An alternative.
Cutting with sharp scissors then melt the ends (carefully) works.
or gas powered cheap one
L INK
Some of these come with soldering bits as well. Double the use, may justify the cost.
trextr7monkey
posted on 5/3/18 at 01:40 AM Reply With Quote
I’m not certain if If was a manufactured item or a homemade addition but I saw a powerful Weller soldering iron with a flat blade on the end being used to cut and seal climbing ropes I might have a similar iron going spare if I can find it,
Atb
Mike
posted on 5/3/18 at 01:41 PM Reply With Quote
Not used it for a while, but on my old soldering iron you can change (replace) the end which is held in place with a grub screw.
Could you not fit a cut down scalpel to create a hot blade?
stevebubs
posted on 5/3/18 at 11:36 PM Reply With Quote
This comes with hot air and hot knife - great for both cutting and fitting heatshrink
https://www.maplin.co.uk/p/pro-iroda-solderpro-70w-gas-soldering-iron-kit-n13ar
