Sierra/granada 7.5' 3.64 ratio lsd
stevec33 - 18/6/16 at 05:59 AM
Im selling a 7.5' 3.64 ratio lsd diff, not sure if its granada cosworth or sierra cosworth, came out my westfield running 200hp in good working order, selling due to changing ratio, standard backlash. Looking for £300, collection from Peterborough or arrange your own courier.
mcerd1 - 18/6/16 at 07:21 AM
Measure the output flanges, Granada cossie's use 100mm CV's and sierra cossie's use 108mm ones.....
stevec33 - 18/6/16 at 09:00 AM
Flanges are 108mm accross, thanks
Barkalarr - 18/6/16 at 12:49 PM
Shame that's not a push in shaft - I would have had that !
Is it easy to convert into push in shafts ?
stevec33 - 18/6/16 at 02:04 PM
No idea mate, perhaps someone else may know and comment. Thanks
mcerd1 - 18/6/16 at 06:49 PM
In a word no
if you want to use this one you'll need the rest of the 2wd sierra cossie rear axle bits (or some custom made driveshaft's)
if you don't want to mess about with hybrid shafts or changing the whole lot then your only option for an LSD is an aftermarket one I'm afraid....
[Edited on 18/6/2016 by mcerd1]
stevec33 - 21/6/16 at 10:13 AM
Sold
