Poll: Rear light layout opinions please [View Results]
2up 1down
Large diagonal
Triangle
TVR
Straight
Author: Subject: Rear light layout opinions please
tims31
posted on 30/12/16 at 02:02 PM Reply With Quote
I would like to gather the opinions of the knowledgeable LCB masses on the potenial layout for my rear lights.
I have had a play around in photoshop and come up with a few designs so please have a vote on what you prefer. These layouts have not yet been completely designed around the IVA spec yet so may not be anything like these once I play by the rules.
Opinions please...
2up 1down
2up1down
2up1down
Large diagonal
large-diagonal
large-diagonal
Triangle
triangle
triangle
TVR
TVR style
TVR style
Straight
Straight
Straight
Build: http://www.martinsfurybuild.co.uk/
Mash
posted on 30/12/16 at 02:39 PM Reply With Quote
Straight
Car looks V nice by the way
sdh2903
posted on 30/12/16 at 02:56 PM Reply With Quote
Straight but a smidgen lower
bi22le
posted on 30/12/16 at 03:28 PM Reply With Quote
The 1st or last one for me, if you have to go with them lights. Otherwise I would go for more modern ones.
Please read my ring story:
Matt21
posted on 30/12/16 at 04:10 PM Reply With Quote
1st or last for me too
Instagram: @matt211988
Photobucket
My YouTube
Samuele
posted on 30/12/16 at 04:15 PM Reply With Quote
Casually today I received the four rear lights for my Fury....
there a reason why I am so many (6 pieces)?
and request for VAT?
as regards the position I like the third photo
Kdempsie
posted on 30/12/16 at 04:21 PM Reply With Quote
I'd go with option 1 but perhaps with the main lights 'smidge' lower and maybe the reverse and fogs a little closer together.
I went with a slightly different look for my lights, see attached link just for info.
https://jpsc.org.uk/forum/viewtopic.php?f=4&t=1209&start=30
adithorp
posted on 30/12/16 at 05:17 PM Reply With Quote
I'd go for No1 but move the fog and reverse closer. The bit below the number plate is the flattest/squarest for the fog requirements without having to make a plinth.
http://jpsc.org.uk/forum/
gremlin1234
posted on 30/12/16 at 05:27 PM Reply With Quote
I quite like the triangle one, however, you will also require rear red reflectors,
avagolen
posted on 30/12/16 at 09:24 PM Reply With Quote
Hi Martin,
Just seen this post. Interesting. I bought a similar amount of lights for my Fury.
I did not use the reversing lights as I thought it made the rear too cluttered.
I put the stop/tail and indicators as in picture 1. I then put the Fog light central below the number plate.
(I think there may be a fog light with a reversing light in the centre available now.)
For the reversing light, I put a completely different light in a suitable position. It is mounted with a single ally bracket and is held in place with a single bolt that I drilled out for the wires to pass through.
I have to say that the reversing light is the only part that I changed on the whole car after it was on the road.
All of the lights have fibreglass plinths that ensure that all are vertical, not for IVA reasons but for aesthetics.
It was a long process to manufacture the plinths, but worth it.
HTH
Len.
The Answer for everything, but never the last word....
snapper
posted on 30/12/16 at 09:58 PM Reply With Quote
Yup I'm going first or last with a bit lower
Thank you for this I have just bought an old Fury with a busy rear end that I know needs changing
I eat to survive
I drink to forget
loggyboy
posted on 30/12/16 at 10:36 PM Reply With Quote
Try a 'shop with them following the radius of the outer edge. Tail/stop at top, indicators at quadrant of radius and fog/rev horizontally symetrical with stop/tail on bottom.
Also the same radius principle, but indicators at extreme edge then move up and in to stop/tail then fogs (in this order remember to allow for min seperarion of fog)
Also, is the plate to scale? I've always found that kits are so small they come up much larger than you expect.
[Edited on 30-12-16 by loggyboy]
Mistral Motorsport
tims31
posted on 30/12/16 at 11:24 PM Reply With Quote
Originally posted by Mash
Straight
Thanks, I'm moving towards straight with a few adjustments
The lights are LED's show should give a good brightness, not really keen on the hamburger or bullseye ones.
tims31
posted on 30/12/16 at 11:27 PM Reply With Quote
Yep, think I agree but will have to see how that fits in with the IVA regs, moving the stop/tail and indicator slightly lower.
tims31
posted on 30/12/16 at 11:41 PM Reply With Quote
Originally posted by avagolen
Hi Martin,
HTH
Len.
Hi Len,
I'll have a play with photoshop and see how it looks with the fog and reverse under the number plate but spaced apart, I like the symmetrical look.
I have got some plinths that came with the lights but will probably cut these down so they just surround the outer edge of the light and make the lights vertical. It is just the Fog that needs to be 90 degrees for IVA but like you say for the aesthetics too.
Found this light on CBS which I may give a try. Could easily sit under the number plate in the middle of the rear and suit for Rear fog and reverse.
[Edited on 31/12/16 by tims31]
tims31
posted on 30/12/16 at 11:45 PM Reply With Quote
I think I understand what you mean will have a play and see what it looks like.
No the plate isn't to scale just what I thought would be about right so I could see how it worked with the lights, will take some pictures again next week when I'm off work so I get the correct scale and use an old plate I have in the garage.
tims31
posted on 1/1/17 at 03:40 AM Reply With Quote
I think the main concensus of opinion is to go with the two straight stop/tail indicator setup which I have lowered slightly and found this rear oval fog/reverse combination on Car Builder Solutions and added that below the number plate in the middle. Also they have some small oval reflectors too which match the shape of the fog/reverse light.
Only thing is, the fog emits red light but has a clear lens, looking in the IVA manual it just states it must emit red light so figure it will be OK as it has the required markings on 'E' 'F' etc. Has anyone else used this lamp at IVA or used a clear lens fog light???
