Author: Subject: SVA booked, please check for deliberate mistakes
justinnewton
posted on 1/3/09 at 10:00 PM Reply With Quote
Well I have submitted my SVA paperwork so I guess it wont be too long before the big day. It will be trailered to the boys at Mac 1 the day before but I'd like to get everything done that I possibly can to give myself as little stress as possible on the day. Please can you guys check the pics and let me know if I've (purposely) made any errors. Cheers.
P.S. I've already put the standard wheel back on and I'm in the process of making a gaiter for the handbrake. I'm also aware that I need to raise the height of the rear foglight which is currently hidden under the back of the car.
MakeEverything
posted on 1/3/09 at 10:06 PM Reply With Quote
check the books wording on the front arches. They need to cover the wheel at certain angles from the centre.
Kindest Regards,
Richard.
handyandy
posted on 1/3/09 at 10:08 PM Reply With Quote
nice car,
only thing i noticed was position of the mirrors, seem to be set quite low & why are they angled towards the cockpit in that way?
unless you like looking at yourself???
smart colour scheme too
andy
MakeEverything
Quoted from Version 3.2 of the IVA manual;
1.
The vehicle must be fitted with wheel guards
2.
The wheel guard must extend at least 30 degrees from the centre of the wheel to the front ( figure 1 )
3.
The wheel guard must extend at least 50 degrees from the centre of the wheel to the rear ( figure 1 )
4.
The wheel guard must cover the full breadth of the tyre throughout the required dimensions ( figure 1 )
5.
The rear of the wheel guard must not terminate above a horizontal plane of 150mm above the wheel centre. See note 1 ( figure 1 )
Kindest Regards,
Richard.
MakeEverything
posted on 1/3/09 at 10:10 PM Reply With Quote
Quoted from SVA Manual
1. The vehicle must be fitted with wheel guards
2. The wheel guard must extend at least 30 degrees from the centre of the wheel to
3. The wheel guard must extend at least 50 degrees from the centre of the wheel to
4. The wheel guard must cover the width of the tyre throughout the required
5. The rear of the wheel guard must not terminate above a horizontal plane of
Kindest Regards,
Richard.
jake_truck
posted on 1/3/09 at 10:13 PM Reply With Quote
Hi.
Really nice looking build, but maybe a couple of things to check.
The front indicators may be too close to the nose cone. I forget the actual distance, might be 400mm from outside of car.
The upper harness mounts could cause problems as the harness rises up to the slots in the seats. I failed on that and mine were lower.
Check for radiuses on the front steering and suspension components as your indicators aren't mounted on extension arms.
Also the ally plate you have used to trim along the inner edge of the cockpit. Is the radius ok?
Plus the mirrors and front arches have been mentioned already.
john
Steve Hignett
posted on 1/3/09 at 10:17 PM Reply With Quote
Front indicators width
Screw in middle of dash
Steering wheel
Seatbelt anchoring
Nut covers SVA Trim etc
Under dash wiring covering
And the other stuff already mentioned
Oh, and you already have a No. Plate
Edited to add, front grille will fail too.
[Edited on 1/3/09 by Steve Hignett]
omega 24 v6
posted on 1/3/09 at 10:48 PM Reply With Quote
Front indicators to far inboard max 400 from widest part of vehicle. Rear eflectors (presume that's them either side of no plate????) Also need to be no more than 400mm from widest point which will be the rear arches.
chequer plate trim on the sides may be a problem the bars can be quite sharp/abrasive.
And when you move your fog keep it a min of 100 mm from the brake light.
trim the seat holes where the belts come through.
[Edited on 1/3/09 by omega 24 v6]
Danozeman
posted on 1/3/09 at 11:05 PM Reply With Quote
The things already sad plus a reflector on the back.
Lovely looking car!!!
Dan
wilkingj
posted on 1/3/09 at 11:39 PM Reply With Quote
Wing mirrors look too low - you ned to be able to see certain marks on the road behind you at certain distances and angles. They look far to low.
Look in my archive... pages from the SVA manual are there for the line layouts.
Front Mudguards - rear should be below the axle centre line, front should be forward of a vertical line from the frontmost part of the rim (not the tyre).
Seatbelts through the hole in the seats. If they touch the side of the hole when beign worn the seat needs to be certificated to take the stress. Most people take the belt out of the hole, and put them back after the SVA.
Front indicators do not appear to be less than 400mm inboard from the widest part of the car (usually the rear wing)
Are those rear reflectors big enough and I'm not sure if they need to be "E" marked or some sort of approval marking.
I am assuming this is going for a SVA and not an IVA.
Finally good luck with the test.
Best Regards
Geoff
http://www.v8viento.co.uk
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 1/3/09 at 11:42 PM Reply With Quote
do the reflectors need to be closer the edge of the car?
u-trim around around the front mud guards
and what everyone else said
skippad
posted on 2/3/09 at 12:12 AM Reply With Quote
Handbrake needs a boot to cover sharp edges
JamJah
posted on 2/3/09 at 12:30 AM Reply With Quote
Whats hanging down from the gearstick?
This is personal advise or personal opinion.
Constructive comments gratefully recieved, picking is left for noses.
blakep82
posted on 2/3/09 at 12:35 AM Reply With Quote
if its not been SVAd yet, why has it already got a number plate on it?
________________________
blakep82
posted on 2/3/09 at 12:37 AM Reply With Quote
and fog light seems to be tucked away?
if its not, and its actually very slimline, where did you get it from?
speedyxjs
posted on 2/3/09 at 07:14 AM Reply With Quote
Things i noticed are:
Screw in middle of dash radius
No trim round front wheel arch (radius)
Wheel arch position (already mentioned)
posted on 2/3/09 at 10:15 AM Reply With Quote
Is the rear view mirror suctioned on? If so they might not like it IE they might deem it removable and test it with it removed.....
and yes, how has it got it's registration plate before SVA?!?!?
justinnewton
posted on 3/3/09 at 07:39 PM Reply With Quote
Thanks for all the replies so far guys, I'll be in the garage on Thursday next so will aim to put some of these things right. At the risk of sounding really stupid, as I used a single donor car for my build I was under the impression that I could use that car's identity. Have I got the wrong end of the stick???
blakep82
posted on 3/3/09 at 07:42 PM Reply With Quote
nope, its up to the inspector if you can keep the reg plate on the car. so you'll take it to SVA with no plates, he'll tell you you can use the donors reg, then you put them back on. (i think)
coz at the moment, that reg still belongs to (presumably) a sierra, and driving a 7 with its plates would be illegal
