Author: Subject: Hinging bonnet
speedyxjs
posted on 1/6/09 at 07:56 PM Reply With Quote
Hinging bonnet
Ok, im a bit stuck on this one.
My plan is to make a full fibreglass front end incorporating lights.
I would like to have it hinge at the front at the bottom, ala E-type:
The problem i am having is how to have it hinge without hitting the ground when fully open.
I could make it removable but dont fancy the idea of trying to shift 2m x 1m fibreglass on my own.
My dad had a great idea of cutting it down the middle and hinging it at the bottom on both sides but as cool as that would look, seem like alot of work.
Anyone got any other ideas?
[Edited on 1-6-09 by speedyxjs]
Flamez
posted on 1/6/09 at 07:58 PM Reply With Quote
I used to have a triumph herald vitesse that hinged at the front. It might be worth having a look at those mechanics?
my build mac1motorsports
blakep82
posted on 1/6/09 at 07:59 PM Reply With Quote
you just need to get the hinge as far up the front as possible. it may mean cutting a lot out the bottom of the nose cone though
________________________
handyandy
why not hinge the bonnet where it meets the nose cone, tho i,m not sure if thats the layout of bodywork you are using.
andy
speedyxjs
posted on 1/6/09 at 08:00 PM Reply With Quote
andy
No, the nosecone will be part of the bonnet
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 1/6/09 at 08:06 PM Reply With Quote
How about allowing it to hit the ground, but on the bottom of an overrider or somthing where the scratches either couldn't be seen, or the bit that gets scratched is sacrificial, or easily replaceable?
Also the 'stop' doesnt have to be the ground, it could be a wire/cable, or a rod sliding through a hole.
Last point is the position of the pivot/fulcrum in space. The more forward and higher it is the less the drop of the bonnet, ie if it is at the very front and quite high, the bonnet may lift away from the ground!
On my cobra I designed big U-shaped hinges to lift the bonnet like a kitchen unit door.
Good luck.
mr henderson
posted on 1/6/09 at 08:15 PM Reply With Quote
Dutton Phaeton hinges at the front, good system too. As Blake says, just need to get the hinge in the right place. If necessary you could use a more complex hinge to push the bottom front up and uot at the same time. A look at an old fashioned convertible hood mechanism will put you on the right track
John
blakep82
posted on 1/6/09 at 08:20 PM Reply With Quote
the problem with that jag, is the hing point appears to be just in front of the wheels. well, its not a problem, as it looks very good, but if the hinge was like, in the front grill, the front wouldn't drop down at all.
you need to find somewhere in the middle
or, as said, some kind of ali or stainless plate which can be replaced
DaveFJ
posted on 1/6/09 at 08:21 PM Reply With Quote
a couple of brackets a bit like they use on lambo doors or sofa beds??
Dave
Daddylonglegs
posted on 1/6/09 at 08:29 PM Reply With Quote
Beaten to it!
robinj66
The nose cone on my Robin Hood hinges forward. I used a couple of old gas rams to stop it hitting the floor. They are adjustable ones from RS Components that had most of the gas let out so they were perfect. A pair of old worn gas struts would do the job.
[Edited on 1/6/09 by robinj66] Rescued attachment PA190011.JPG
MautoK
posted on 1/6/09 at 08:30 PM Reply With Quote
speedy,
I've hinged my MK's nose cone onto the bottom rail at the front. It's prevented from hitting the ground by a highly technical mechanism - a loop of nylon cord.
With a bit of experimenting you should be able to rig a double-link hinge (as implied above) to allow your composite nosecone/bonnet to open far enough for adequate access - and a stay (or even tailgate struts) should be fairly easy to incorporate.
Just my .02c
John.
andrew-theasby
posted on 1/6/09 at 10:08 PM Reply With Quote
Im not far away from completing mine like this. my hinge point is about 2" infront of the bottom chassis rail on a couple of spherical bearings. Ill post some pics in a couple of weeks when its done but check google for wcm ultralight
Canada EH!
Take a look at a Series 4 Lotus 7
JonBowden
posted on 1/6/09 at 10:10 PM Reply With Quote
I haven't had time to read this whole thread yet, so I might be missing the point but ...
this car hinges forwards. Somewhere in that site they show that they use small gate hinges I think
http://www.angelfire.com/biz6/stalkerv6/
Jon
Simon
posted on 1/6/09 at 11:13 PM Reply With Quote
speedy,
All you need is a couple of cheap B&Q hinges. laminate in correct place at bottom of nosecose, the drill a couple of holes in lower rail for screws.
Deimos has been like that for about 5 years.
Sure there's some pics somewhere
Simon
Simon
posted on 1/6/09 at 11:21 PM Reply With Quote
[img] Engine from offside
Engine from offside
[/img]
Simon
iank
posted on 2/6/09 at 06:45 AM Reply With Quote
Fozzie's car has a piano hinge down the middle, classic car style.
Click me for a big picture
Anonymous
Vindi_andy
posted on 2/6/09 at 08:38 AM Reply With Quote
Ill try and get some photos of my arrangement tonight for the vindicator bonnet. To stop is hitting the ground Ive used a couple of lengths nylon covered wire rope. Got some left over if anyone needs some.
speedyxjs
posted on 2/6/09 at 04:11 PM Reply With Quote
Cheers guys.
I was going to make a fozzie-esque bonnet but have no room for a bar down the middle to hinge it on
Mave
posted on 2/6/09 at 07:22 PM Reply With Quote
Here's my bonnet. It hinges on two stainless steel garden fence hinges. The long part of the hinge is reinforced with some stainless still strips to make is U-shaped. It hinges relatively far in front of the chassis.
I'm changing back to the standard separate nose and bonnet though. Makes life easier (but my bonnet will hinge on scuttle).
[Edited on 2/6/09 by Mave]
speedyxjs
posted on 3/6/09 at 09:13 AM Reply With Quote
Cool, thanks guys
I think iv got enough to plan it now
