New Topic New Reply
Author: Subject: Fu tubes
goodguydrew
posted on 6/2/10 at 05:42 PM Reply With Quote
Fu tubes
I've just spent a happy afternoon repositioning my Fu tubes after realising I had fallen onto the steering column fouling trap.
Steve Hignett
posted on 6/2/10 at 11:15 PM Reply With Quote
Gutted.....
James
posted on 7/2/10 at 12:34 AM Reply With Quote
Drew,
Don't know how far you've got and can't tell from your photo archive.
But it's worth leaving FU1/2 until your wishbones are done and you're attaching the wishbone brackets. As you've found FU1/2 are so hard to get right, it's worth using wishbone placement as your guide to get them right.
Making a jig as per my photo archive will help you.
Sorry if you've already got past this point and I'm teaching you to suck eggs!
James
NigeEss
posted on 7/2/10 at 12:44 AM Reply With Quote
Geez James,
You've so many pics/folders cand you give a clue where the jig is
Steve Hignett
posted on 7/2/10 at 10:02 AM Reply With Quote
The Jig photo's were in a folder called Bracket Jig...
The plans
The plans
Jig from front
Jig from front
Jig from rear
Jig from rear
James
posted on 8/2/10 at 02:23 PM Reply With Quote
Thanks for that Steve.
I missed Nige's post.
The Doc
posted on 9/2/10 at 08:22 PM Reply With Quote
Don't let's forget maybe that's why uncle Ron called them FU tubes.
Q: Who wants to live until they're 80?
A: Someone who's 79
goodguydrew
posted on 13/2/10 at 11:09 PM Reply With Quote
Thanks for the replies. James, I already knew about your jigs idea. Very good, infact I made one too. However, I positioned the bottom of the Fu toubes too far inward and the tops too much outward. The result was the bottom of the Fu tube fouled the steering shaft.
James
posted on 16/2/10 at 01:04 PM Reply With Quote
It's so easy to get them wrong . One of my brackets needed a bit of 3mm strip behind it to get it right- even with the jig!
Fitting the wishbones can help you get the brackets right, you can use a small line and plumb to get your 22*mm castor if you thread the string through the upper threaded BJ part.
HTH,
James
* assuming you're using book wishbones/dimensions
[Edited on 16/2/10 by James]
New Topic New Reply
