Author: Subject: Compressor (Again)
The Doc
posted on 20/2/10 at 02:12 PM Reply With Quote
Compressor (Again)
OK compressor is now working fine except:
As the auto cut out had packed up I bought a new one. One of the features it has is an automatic pressure dump valve which should release the air pressure when in the off position, which it does. Trouble is that it also does this every time it performs the automatic cut out.
The valve is mechanical and operates when the button on the unit is depressed, which happens both when manually switching off and on auto cut out. This is not a separate solonoid, just a mechanical linkage. The supply to this valve is via a free line which was available from the tank.
(There is no direct connection between this port and the others on the unit)
I could simply bypass it but that it seems a shame not to take advantage of this function.
Any ideas?
TA
Mike
Q: Who wants to live until they're 80?
A: Someone who's 79
dan__wright
posted on 20/2/10 at 03:00 PM Reply With Quote
thats normal, it removes pressure from the pump so when it starts up it can gett running before its fighting 50 psi.
FREE THE ROADSTER ONE…!!
Stuart_B
posted on 20/2/10 at 03:29 PM Reply With Quote
as said, it is doing it jobs, it is so the motor does not have to start up under pressure.
stuart
The Doc
posted on 20/2/10 at 07:04 PM Reply With Quote
Why doesn't it just let the use of the tools, spray gun etc. bring down the pressure?
A: Someone who's 79
posted on 20/2/10 at 08:17 PM Reply With Quote
Do you mean the valve is venting tank pressure ? It should only unload the pressure above the piston in the cylinder, you are missing something somewhere if it is constantly blowing pressure off. There should be a thin plastic pipe from your cut off switch to the line feeding your tank from the pump head where it couples into the tank non return valve.
[Edited on 20/2/10 by Peteff] Rescued attachment airmaster.jpg
