New Topic New Reply
Author: Subject: Caterham chassis
dave
posted on 13/6/10 at 06:53 PM Reply With Quote
Caterham chassis
Does anyone know where i can get the dimensions for a caterham chassis. Prefer online.
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 13/6/10 at 07:59 PM Reply With Quote
There's a load of stuff like specs on the owners site.
Otherwise you could ring Arch who made them (sorry, not on line).
Guinness
posted on 13/6/10 at 09:53 PM Reply With Quote
There have been a lot of different models of Caterham, the standard Arch chassis, then the SV (which is wider). I think the CSR is also a different size.
But this might help as a basic guide:-
Cat Dims
Cat Dims
Stott
posted on 14/6/10 at 08:58 AM Reply With Quote
16" steering wheel!!!!!!
5 turns port to starboard lol
86barettaguy
posted on 20/7/10 at 09:19 PM Reply With Quote
hey, that's even narrower than the champion book chassis! And here I was worried about fitting into the standard locost cockpit!
would be interesting to see the measurements for the current caterham lineup as well Maybe my buttocks don't need as much space as I thought :-D
Steve Hignett
posted on 20/7/10 at 09:58 PM Reply With Quote
Is it just one or two Dims you need to know? If so then I have a Caterham at nearly bare chassis stage at the moment that I can measure for you, but I'm afraid I don't really have the time to measure every tube etc!
86barettaguy
posted on 21/7/10 at 07:45 PM Reply With Quote
me, I would be happy just to have the cockpit widths and maybe some other basic measurement to compare with the book frame. can't speak for anyyone else though
Bare
posted on 24/2/11 at 05:25 PM Reply With Quote
Yes I realise that this is an older posting.
However I'm after the distance between the upper and lower Arm, frame mounted pivots (centre to centre?) on the front suspension on a Cat chassis. Rear main mounts only will be fine.
I have conflicting numbers and need to know what it actually is... as measured.
I hope (?) this is still possible?
Thank you
New Topic New Reply
