derf
posted on 25/5/04 at 02:32 AM |
Recieved my body work today, some questions...
I took delivery of the nosecone and scuttle today, the nose fits fine, but the scuttle doesnt.
The problem with the scuttle is an easy fix, I mounted the steering colum mount in the same place as the scuttle attaches, I was just going to cut a
bit off both, and make it fit.
My main question is how to mount the nosecone, there really isnt a lip on the edge that meets the upper frame rail, there is a small one, but not big
enough for fasteners. Is there something I'm missing. Please post photos.
Adding photos
Trail fit of body work
body work trial fit
The steering colum mount that needs cutting
problem with scuttle
Isnt there supposed to be a lip that sits on the frame? There is one about 1/4 inch, not big enough to use a fastener.
isnt there supposed to be a lip here? (nose)
I was originally going to drill a hole through the frame and the lip on the nose, and run a steel nub up through the frame, weld it from the bottom,
and then just have a pin hold it on, then put a hinge at the bottom front so I could rotate the nose forward to give me access to the radiator
assembly
[Edited on 25/5/04 by derf]
posted on 25/5/04 at 08:28 AM |
ive put hinges on the bottom of my nose, it makes it very easy to get on and off. I think the easiest way to sort the other end of the nose may just
be to fiberglass something onto the nose, that can be bolted down. On mine, im just going to drill a hole i think, and bolt it to a bracket.
splitrivet
posted on 25/5/04 at 08:57 AM |
I just welded a piece of 2 inch wide 1/8 strip to the top chassis rail behind the bonnet lip derf so that the fixing is hidden by the bonnet.
Looks like youll have to rethink your steering mount tho.
Bob
