Author: Subject: Electric fuel pump location
The Doc
posted on 20/5/11 at 04:10 PM Reply With Quote
I note that many people site the electric fuel pump near the tank. Any reason why this shouldn't be in the engine bay? Fitting a pair of Dellortos and therefor 'going electric'. Easier to take a power supply from under the bonnet.
TA, Mike
Q: Who wants to live until they're 80?
A: Someone who's 79
carlknight1982
posted on 20/5/11 at 04:21 PM Reply With Quote
most pumps are designed to have a short pull and a long throw. putting them closer to the tank makes it easier for the pump to "pull" the fuel before "Throwing" it downt he fuel lines into the engine bay.
If your going Carbs remember you may need a fuel pressure regulator.
Logic will get you from a A to B
Imagination will take you everywhere.
posted on 20/5/11 at 04:28 PM Reply With Quote
Mounting close to the tank and low down avoids vapour locks forming in the suction side of the pump.
coyoteboy
posted on 20/5/11 at 04:49 PM Reply With Quote
Yup, they blow better than they suck, it's easier to blow through long runs of pipe than suck so much better to run the high pressure side the furthest.
big_wasa
posted on 20/5/11 at 06:15 PM Reply With Quote
You can get low presure sucking pumps that are perfect for webers and are designed to sit in the engine bay. Brand name Huco as sold by webcon. Mine fills my swirl pot in the engine bay. For carbs you dont need any extra regulators.
Craigorypeck
posted on 24/5/11 at 10:57 PM Reply With Quote
I ran a Huco suction pump in my engine bay and any prolonged high rev driving and the engine would die, thought it was a dodgy fuel line so replaced it all... still happened, when engine cut out the pump would be going flat out trying to fill the float bowls, pinto on 40s and not running rich. prob solved with a red top on the chassis rail in the bay at the same level as the sender unit and filter king on the wing.
